Author Topic: Griso Remap GuzziDiag Questions  (Read 2297 times)
Offline Bbbbbad
« on: June 05, 2020, 12:28:22 PM »
Hi guys, new owner here who's read up a bit but I have a few questions if anyone can point me in the right direction
My 1100 Griso seems to ride well (I've already read up and set up the suspension) but as I've never owned a Guzzi before, I've limited reference
It's spec is K&N filter, Scorpion end can with no baffle, Memjet fuelling device - I see that all three are frowned upon on here but it seems to pull well at the bottom and mid range but the only thing that happens above 6k is increased vibration (which is the opposite of what I've read with these mods) I've contacted Beetle to see if his map will work for me, I'm willing to lose the filter and memjet but do I really have to lose the endcan ?
I have seen the MG Termi for the 8v for sale, I presume that will fit mine and I'm willing to give it a try
I've already bought and set up the GuzziDiag and downloaded my existing map - is there anything else I can do with it ?
My "Service" light is on, I've looked at the codes and reset them and reset the Service light via the dash but it won't go out.
My speedo sensor has died (I have one on order) but surely this shouldn't prevent the Service light resetting (although it won't clear the speedo code)
Offline janguzzi
    • My YouTube Channel (Guzzi Content)
Re: Griso Remap GuzziDiag Questions
« Reply #1 on: June 05, 2020, 12:52:09 PM »
Ask your question here:
https://www.grisoghetto.com/
 :wink: :wink:
Kind Regards
Jan, Schuby (near the Danish Border), Germany
www.janguzzi.de
-1992-2002: 1000S, 2nd Series
-2002-2004: V11 Le Mans "Grigio Titanium"
-2004-2011: V11 Le Mans "Rosso Corsa" & 2008-2011: 950S
-2018-2021: California Vintage
-2011: Griso 8V & 2023: V85 TT "Giallo Mojave"
Offline Bisbonian
  • Living the Dream
« Reply #2 on: June 05, 2020, 01:26:38 PM »
You'll get a lot of opinions about the memjet.
You may want to try it with the baffle in the pipe.
No reason it shouldn't run well with the aftermarket can (see comment about baffle above).
Beetle should have a map for the 1100 Griso and it's worth a shot.
« Reply #3 on: June 05, 2020, 01:29:23 PM »
Are you getting the "service light" or a wrench icon?
Offline Bbbbbad
« Reply #4 on: June 05, 2020, 01:41:19 PM »
 :wink: :wink:
I can try but the vast majority of info I found about GuzziDiag was from here
Offline Bbbbbad
« Reply #5 on: June 05, 2020, 01:45:32 PM »
I agree the memjet is at best a bodge and from what I've read Guzzis already run rich at higher rpm - the exhaust is sooty too
On my KTM i had to fit an O2 optimiser as it would shake below 4k as standard, my Griso seems fine in that respect
The best bit about the bike is the noise, particularly on the overrun
He does have a map - just one, unlike the 8v
Offline Bbbbbad
« Reply #6 on: June 05, 2020, 01:46:29 PM »
The word "Service"
Offline 80CX100
« Reply #7 on: June 05, 2020, 02:19:56 PM »
      The speed sensor problem can apparently affect all sorts of things, it should be fixed and in good order as a baseline first.
      I'm not sure what the Memjet thing is, but disconnecting it and installing Beetles map would give you a known starting point.
      Doing a proper tune up, may possibly fix any running issues,,, ie adjust valves, TPS, then synch/balance throttle bodies.
      Good luck
      Kelly
2008 California Vintage
2003 V11 Lemans
1979 G5 & 1980 Lemans CX100
beetle
« Reply #8 on: June 05, 2020, 07:18:25 PM »
Scorpion. Right.
I just responded to your email, but you didn't mention the brand of exhaust. Now I know, the answer is "yes".
Offline Bbbbbad
« Reply #9 on: June 06, 2020, 01:35:55 PM »
Would anyone know whether the speedo sensor (or lack thereof) would be causing the "Service" warning ?
The speedo fault code won't clear so it's possible - I'm awaiting one from Europe (half the price of UK)
Does the service warning have any effect (other than being mildly annoying)
beetle
« Reply #10 on: June 06, 2020, 06:12:48 PM »
Yes. You won't be able to clear it until you replace the speedo sensor.
A bad speedo sensor can cause all sorts of weird things to happen.
Offline 80CX100
« Reply #11 on: June 06, 2020, 06:45:06 PM »
     I can confirm what Beetle says about it causing weird problems, albeit 2nd hand info.
     I purchased a higher mileage (58K) 2007 Griso that had the fix done already by the previous owner. He advised me that the speed sensor had caused a variety of frustrating symptoms that completely stumped him; to the point he thought it was the legendary digital dash issue, and bought a NOS dash, before he figured out it was the speed sensor.
     If you search, there should be lots of info on here and grisoghetto on the proper repair procedure.
     Iirc it's not just a straight swap, it also involves well placed silicon or sealant to permanently fix it.
     Good luck
     Kelly
2003 V11 Lemans
Offline Bbbbbad
« Reply #12 on: June 08, 2020, 04:49:48 AM »
Thanks - still plenty to play with while I wait for the sensor
