I need to replace the seals on the clutch shaft.
Which seals ?I had no problem with the rear wheel and guard removed, swinging the swing arm backward complete with the bevel box back off the shock absorbers.Swinging it back in, engaging the splines was easy then putting the pivot pins in by myself.I am sure with two people what you want can be done easily but comes back to the seal you are talking about.
Clutch pushrod seals...
Getting the swing arm back in works best having it angled with the rear of it near the ground so if the wheel is on you can't do that. If you try with the swing arm parallel to ground it's difficult if not impossible getting it in the frame brackets to put in the pivot pins.
Remove the wheel, pull the swing arm rearward.Needle nose pliers will get to the push rod.That area has nothing to stop crud getting to the plunger, I cut up a clutch cover (Ducati) to make a bellows/seal while I was there.)https://ducati-gowanloch.com/shop/rubber-parts/ducati-clutch-cable-boot/
This site is the BEST...So I remove the rear wheel, and only pull the swing arm back, but not off completely... excellent!Needle nose pliers will get the shaft out.... OK (I am bummed that I left all my reference books at a different location.
