I still need help... I bodged up a tool from a 3/8" bolt and two nuts locked together. It worked fine. I found my seven so I could get the brake caliper off. I removed the two little pinch bolts from the bottom of the right fork leg. The axle started to turn quite easily. I decided to leave the wheel on the ground until the axle was loose. The axle became impossible to turn, just as the face of the right side, the Allen side, was flush with the fork bottom. I tried and tried and could not budge the axle -- in either direction. I put it all back together in disgust, feeling like a damn duffer. I sprayed silicone spray on both ends of the axle. Nothing worked. What did I do wrong? Help me, guys....
My V7 came with a short piece of 14 mm hex section
Malik, you mean the axle spacers, not the black spacers between the caliper and the ears on the fork slider, right? ......
