Author Topic: V85 facelift  (Read 123932 times)
Re: V85 facelift
« Reply #240 on: November 14, 2021, 08:39:31 AM »
I always thought the Wire wheels on the Norge knocked it out of the park
Yeah.
I’ve only fixed one leaking spoke nipple since early 2016 @90,000 k. Now they are at 195,000 k.
As for the V85...
I do prefer the polished look of the V85 ones compared to the original black.
« Last Edit: November 14, 2021, 08:46:10 AM by Huzo »
Offline Brand X
Re: V85 facelift
« Reply #241 on: November 14, 2021, 10:20:58 AM »
Yeah.
As for the V85...
Same on my Stornello, but going the with stock blacked out rims for the near future.  The rear hub is bead blasted aluminum, and the front is painted  silver from the factory.. The aluminum side cover # plates, and front shield was a bit over the top, and black works better for me.. Kind of a kit looks wise from the factory, and the black stuff looks better overall to me.. Funny ordered a chrome racer tank from Ebay, and i am going to bling it out some.. It will take some work to pull it off, but I have a feeling I might pull it off. Main thing just store the original mint parts for down the road. Love the aluminum fenders though..
If I can figure out a way to satin the chrome tank by blasting/etc might go that route . Ordered some H&B stickers that look like the Breva/Norge badges,and side factory rubber tank pads from AF1
Great thing about these bike is you can make it look like your own, and it does not matter one bit if any one else likes it.. You would not be riding a guzzi if you cared what other people thought about it.. :evil: Probably a BMW instead.. :grin:
Offline SSGG Geezer
Re: V85 facelift
« Reply #242 on: November 20, 2021, 09:26:49 AM »
I love the look!
I just got my C85 delivered and like the look of the Travel but yours is sweet! Great work.   How much weight did the exhaust save you?
Re: V85 facelift
« Reply #243 on: November 20, 2021, 10:26:18 AM »
I love the look!
My educated guess is around 10 kg total.
My pipes are single wall and there is no cat converter. The Mivv muffler weighs about 3 kg.
Offline henwilv
Re: V85 facelift
« Reply #244 on: November 20, 2021, 10:42:26 AM »
In the same way, I still think I prefer steel sunraysia-style wheels on offroaders (cars, utes, landrovers etc.) to alloys for the same reason.  Steel, too, seems more flexible yet resilient than alloy.  As an aside, many steel wheels are actually lighter than the thicker sectioned alloy wheels usually fitted to offroaders too.  We're not talking about Mareshini magnesium racing wheels here, but just el cheapo OEM crap standard fitting alloys.
You can also hammer steel to bend it straight if you ding it hard, a big plus if you are out somewhere in the middle of the bush!
Offline lucky phil
Re: V85 facelift
« Reply #245 on: November 20, 2021, 05:13:08 PM »
I think it’s turned into a tummy tuck, more than a facelift.
The whole thing just looks.....lighter.
I like the empty look under the rear guard. The muffler is a bit rorty, but tomorrow I’ll fit the dB killer to tone it down a bit.
It sounds nice under load on the freeway, but just a touch loud.
A bit of a walk around.
https://youtu.be/W9ulUhJgVwk
Oh and BTW..
The link pipe you see is a mild steel pattern I threw together. The finished article will be mandrel bent stainless.
Ha, surprise me :laugh: You've got an absorption muffler of those dimensions on an 850cc engine. It ain't going to be anything less than "a touch loud" under load.
Ciao
« Last Edit: November 20, 2021, 05:16:54 PM by lucky phil »
Offline lucky phil
Re: V85 facelift
« Reply #246 on: November 20, 2021, 06:05:37 PM »
Actually Phil, it’s not offensive and it does not have a dB killer in, so it should be closer to acceptable with one fitted.
That actual muffler is not mine, but I’ll be getting one the same. I borrowed it to do the work.
You're going to struggle to achieve an acceptable DB level with such a small volume. I find DB killers tend to reduce the DB level but have a negative effect on the "sound" or tone of the pipes. Having said that I run them on my RE 650 to reduce the "crack" from the exhaust but it doesn't sound as good. Even my 48 hp 650 RE is bordering on too loud with 2 absorption mufflers and DB killers of about the size of your borrowed one.
My V11 Agostini cans aren't objectionable even without DB killers but they have plenty of muffler internal volume.
Ciao
Re: V85 facelift
« Reply #247 on: December 06, 2021, 04:15:25 AM »
Seriously, cannot think of much else.
There’s been.
30 mm reduction in seat height
Ohlins shock
Tom Tom mount
Front beak removal
Low front guard
Denali auxiliary lights
Polished rims
Bash plate removal
Mandrel bent headers
Y pipe into Mivv low muffler
Black removal from swingarm, drivetrain and hubs
Top case mount moved 100 mm forward
Hand guard removal
Throttle pull halved
Poor reserve light activation point fixed
That’s got most of it I think...
« Last Edit: December 06, 2021, 04:30:32 AM by Huzo »
Offline lucky phil
Re: V85 facelift
« Reply #248 on: December 07, 2021, 12:50:43 AM »
There’s been.
Ohlins shock
Tom Tom mount
Front beak removal
Low front guard
Polished rims
Bash plate removal
Hand guard removal
Time to sell it then I guess :grin:
Ciao
« Last Edit: December 07, 2021, 12:51:32 AM by lucky phil »
Re: V85 facelift
« Reply #249 on: December 08, 2021, 04:08:04 AM »
Ciao
Hmmmm...
That might be an issue. If I took 10 grand off what it owes me, I’d still need to get 20 k...!
I’m afraid she’s a keeper.
(Lucky she’s pretty..) :kiss: :kiss: :kiss:
« Last Edit: December 08, 2021, 04:11:25 AM by Huzo »
Offline Caffeineo
  • Guzzi B00b
Re: V85 facelift
« Reply #250 on: December 08, 2021, 11:55:14 AM »
I really like the new, low pipe. Makes it easy to put some soft luggage on and I doubt it will have any negative effect anyplace you will be riding it off road. Maybe some manufacturer will pick up on this and you can collect a royalty.  :evil:  :thumb:
2022 Moto Guzzi V85
2023 Husky TX300
2020 KTM 500 XCW
Re: V85 facelift
« Reply #251 on: December 08, 2021, 01:22:34 PM »
Well, that’s a topical subject at present for me.
I was in a conversation the other day with old mate and he said that I have removed my bike from it’s “intended purpose..”.
The (predictable) response was two fold.
If there were 10 bog standard V85’s and 10 replicas of mine on a dealer floor..
Which one would sell out first ?
Also
Other than fitting road tyres and removing the piece of bent tin..(bash plate), what have I done to mine that would preclude it from operating in the same sphere as it was originally envisaged by the manufacturer ?
« Last Edit: December 26, 2021, 05:55:31 AM by Huzo »
Offline Caffeineo
  • Guzzi B00b
Re: V85 facelift
« Reply #252 on: December 09, 2021, 12:28:35 PM »
Also
Other than fitting road tyres and removing the piece in bent tin..(bash plate), what have I done to mine that would preclude it from operating in the same sphere as it was originally envisaged by the manufacturer ?
Well unless you are planning on riding MC only (single track) trails you have not lost any off road ability with the lower exhaust and made it easier to mount side bags. If you do plan on riding single track trails you really should pick another bike. Even if you only ride dirt roads on occasion I think a skid plate is a good idea as there is always some bits thrown up from the front tire. Mostly protection from cosmetic dings.
Damon Bradshaw rides a T700 on some hairy trails with an exhaust about the height as yours. https://www.youtube.com/watch?v=MjshsFzgXlg Of course online everyone rides at the expert level.  :evil: :evil:  :tongue:
2022 Moto Guzzi V85
2023 Husky TX300
2020 KTM 500 XCW
Re: V85 facelift
« Reply #253 on: December 25, 2021, 12:08:28 PM »
I decided that the low muffler did not have enough upward kick.
The rear pegs were preventing any further re positioning in that regard, so out with the hacksaw...
Some prettying up required, but I’m happy with the angle.
Offline egschade
Re: V85 facelift
« Reply #254 on: December 27, 2021, 03:23:01 PM »
Being parallel to the rear subframe/rack makes a nice line. Also like the clear space under the seat.
The elder Eric in NJ
Past Guzzis:
2016 V7 Stornello #394
2018 V7 III Carbon Dark
1985 LeMans 1000
2020 V85TT Adventure
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
Re: V85 facelift
« Reply #255 on: December 27, 2021, 04:26:53 PM »
Yeah, I’m happy with that.
Now I want the engine/gearbox silver... :rolleyes:
« Last Edit: December 27, 2021, 04:27:56 PM by Huzo »
Re: V85 facelift
« Reply #256 on: January 11, 2022, 10:37:42 AM »
This is how it ended up with the panniers on.
There is now a massive space between the inside of the left case and the wheel.
I saw a post where some bloke has fitted a tool case in there.
That engine needs to be silver.
Hmmmm.....
« Last Edit: January 11, 2022, 10:46:41 AM by Huzo »
Offline PJPR01
Re: V85 facelift
« Reply #257 on: January 11, 2022, 11:02:19 AM »
Hmmmm.....
Black engine looks more stealth...color combos look great.  Sounds like the pannier issue is similar to the Stelvio...you could pack an elephant in between the bike and pannier given that the muffler tucks up in between there.  A round tool kit cylinder might be a good choice...but you'll probably need one on the other side to keep it symmetrical or the imbalance will drive you nuts!
Looking good!
Paul R
2015 Red/Black Griso
2008 Silver Norge
2002 V11 Scura
Re: V85 facelift
« Reply #258 on: January 11, 2022, 11:23:27 AM »
Looking good!
It’s too late, I am already nuts..!
But the imbalance thing would not be an issue, because the right hand pannier is wider anyway.
It would actually even it up.
Offline PJPR01
Re: V85 facelift
« Reply #259 on: January 11, 2022, 11:43:03 AM »
 :thumb: :thumb:
Paul R
2008 Silver Norge
2002 V11 Scura
Offline Jorg66
Re: V85 facelift
« Reply #260 on: January 11, 2022, 11:53:04 AM »
Yup ,totally dig it,.... foremost the Look of the Front Fender and Exaust.Very Prime !
Offline DH8a
Re: V85 facelift
« Reply #261 on: January 11, 2022, 03:03:29 PM »
Which headers and crossover did you fit? Any fuelling issues?
2013 1200 Sport 8V
2020 V85tt
Re: V85 facelift
« Reply #262 on: January 11, 2022, 03:32:30 PM »
I made the headers from stainless and were done on a mandrel bender.
The Y piece is Agostini and all TIG welded.
The bike has been re mapped on a dyno and Lambdas disabled. I would have removed them completely (and did) for a while, but the ECU throws an engine light.
Initially there was a very slight dip in the fuelling at 2,800-3,100 rpm under light throttle, but that hole has been mapped out. It now pulls evenly and I think it is more even with the Mivv than the Zard.
I can get 500 km from a tank (just), under ideal conditions but things have to be perfect.
A range of 470 is always achievable.
« Last Edit: January 11, 2022, 03:38:18 PM by Huzo »
Re: V85 facelift
« Reply #263 on: January 11, 2022, 03:44:10 PM »
I have bumped the old V85 TT mods thread.
All the questions about the exhaust are answered in there.
Online Vagrant
Re: V85 facelift
« Reply #264 on: January 12, 2022, 09:33:30 AM »
How did you getrid of the O2 sensors? I thought it couldn't be done.
Re: V85 facelift
« Reply #265 on: January 12, 2022, 10:46:14 AM »
The guy who reworked the map has the ability to switch them off. I specifically asked him if they are still functioning and he said no.
They do need to be plugged into the loom though, unplugging them results in the yellow engine light illuminating and a code being thrown.
I do believe Meinolf has written on this matter recently however.
Re: V85 facelift
« Reply #266 on: January 13, 2022, 02:54:05 AM »
How about this for a left hand compliment...(I think..)
I pulled up today at a place called Halls Gap on my V85. There were a few bikes laying around.
Anyway, one of the punters says..
“Gee that’s nice isn’t it..” (pointing in the direction of my bike..)
One of the other blokes says..
“Ah yeah, that’s one of them Moto Guzzis, it’s ok but I like those TT things more....”  :rolleyes:
« Last Edit: January 13, 2022, 06:24:58 AM by Huzo »
Offline Brand X
Re: V85 facelift
« Reply #267 on: January 13, 2022, 08:06:42 AM »
I am guessing you are doing it more to suit your tastes anyway..  :grin: Always tasteful to me though. I have my polished rims coming for my Stronelllo coming next week. I want to keep two sets of wheels with different looks..
Offline Trialsman
Re: V85 facelift
« Reply #268 on: January 13, 2022, 09:50:32 AM »
Your bike mods are always thought through and well executed Peter.  More people should venture down that road to make their bike truly THEIR bike.
2010 FE570 Husaberg
2019 Alta Redshift EXR
2021 Moto Guzzi V85TT Centenario
2024 Stelvio V100
2026 Bonnell 805 EX
Re: V85 facelift
« Reply #269 on: January 13, 2022, 11:45:37 AM »
Yes T.
I just thought it funny, that our simpleton hero did not recognise my bike as a V85. There was something very primal about him.
