Author Topic: Where should I go to get a good Forking?  (Read 3525 times)
Offline usedtobefast
Re: Where should I go to get a good Forking?
« Reply #30 on: June 28, 2020, 11:30:56 AM »
Makes me wonder.  Do any suspension shops use some sort of linear 'dynamometer' that would allow them to mount a fork leg, or both legs, and run it/them thru a set of computer-controlled movements, at different fps speeds, measuring compression pressure and rebound damping at various parts of the fork stroke, so that there would be a real set of constants one could tune to?
This whole suspension thing seems like such a crapshoot.
I would hope Matris & K-Tech have dyno's and tested things when they developed their kits.  They have a desired curve (test results) they are looking for.
But then a local ish suspension shop that installs a Matris or K-Tech fork cartridge probably does not have a suspension dyno and instead they rely on Matris/K-Tech's testing and setup info.
In the dirt bike racing world, several high end suspension shops have their own shock/fork dyno's and do lots of "lab" testing and track testing.  From that they develop their suspension settings/kits.  When you send your fork/shock to them they do not dyno your fork/shock, but look at their setup notes and revalve your suspension based on all their previous testing.
And if Factory Connection did your suspension, it would probably be different than if MX-Tech or Kreft Moto or Stillwell Performance did it (dirt bike world here) ... as each of these shops have different ideas/theories on what is best.  So they don't even agree on the best test results!   :laugh:
But these guys are not just winging it, crap shoot style.
On the other hand, there could be a suspension shop where a person with a lot of experience just experiments, revalves, rides, revalves, rides keeps refining things until they like the result, no fancy shock/fork dyno.  Then when a customer wants a revalve they use their notes/settings to do that revalve.
2017 V7 iii Racer
2017 Griso
2016 Stornello
2000 Red Quota
Online jhem68
« Reply #31 on: July 04, 2020, 03:51:18 PM »
I have installed the Race Tech springs and Gold valve Kit to my Breva 750 via their recommendations for my weight and riding style. I did the install and damper rod modifications myself over last winter and could not be happier with the results! Compliance was noticeably improved and handling is as good as my skill set allows it to be.
This was one of the two best improvements I've made to that bike along with Ikon shocks and a Brembo RSC front master cylinder. Well, I guess that's three. I'm definitely going to install this set up in my Milano this coming off season.
It looks like about $310.00 for the springs and valve kit currently listed for the V9 series on their website. I would think Bad Chad would be able to handle this with help if necessary from one or more friends.
« Reply #32 on: July 04, 2020, 03:57:45 PM »
Short of losing weight and being shorter.   :rolleyes: That should do it.
Online bad Chad
« Reply #33 on: July 05, 2020, 02:19:10 PM »
Oh you little Rascal Tommy!   I can hardly wait till I see you again and give you a great big Pink Bandana hug!! :afro:
Not sure I want to take the project on myself.  But I’m definitely going to look at having the forks set for my svelte body type.
« Reply #34 on: July 05, 2020, 02:39:08 PM »
 :grin: :grin: :grin:
Have you tried a different wt. oil in the tubes to slow the rebound?  Progressive wound springs would also help or old school remedy.  Cut some spacers and add it to the top of your springs in the fork tubes.  PVC or copper tubing if you have it.  1" or less.  The hard part would be putting the caps back on the tubes.
