Author Topic: 1985 V65 Lario  (Read 7980 times)
Offline egschade
  • Eric - MGNOC NJ Rep - mgnocnj.forumotion.com
Re: 1985 V65 Lario
« Reply #30 on: October 10, 2023, 07:40:35 PM »
$1500 for a cosmetically nice Lario is money well spent, IMHO. Don't be surprised if the motor spins over but has a dead head, though..  :smiley:
If both heads are good, it's a bargain.  :thumb:
Edit: oh, forgot.. there is a necessary rear drive mod on an 85. There's a transmission vent mod that should needs to be done so a full liter of transmission lube can be used. If fifth gear is whining, it's too late. I detailed both here.. somewhere.
What constitutes a "dead head" and how do you determine if a head is good or not?
The elder Eric in NJ
2024 Triumph 400X Scrambler
1971 Honda SL350
Past Guzzis:
2018 V7 III Carbon Dark
1985 LeMans 1000
2020 V85TT Adventure
V65 SP
V7 III Stone
V50
Griso 1200SE Tenni
Breva 1100
EV Touring
Re: 1985 V65 Lario
« Reply #31 on: October 11, 2023, 06:23:29 AM »
Pull a plug, turn it over with your finger in it.. :shocked: :smiley: No compression? She's dead, Jim..
Offline huub
Re: 1985 V65 Lario
« Reply #32 on: October 11, 2023, 07:30:24 AM »
Dusting this off as I've discovered an '86 Lario with 18K miles near me for $1500. Seller states "been sitting' for a while so won't start but engine spins freely. Pictures show a fully intact bike in v. good cosmetic condition.
Is it a fools errand to try and bring it back to life?
sounds like a good deal , worst case it dropped a valve and you'll have to find  a V65 two valve engine to drop in instead of the 4 valve engine.
if the engine is still servicable after new valves and valve springs it should be ok.
these are great little bikes.
Re: 1985 V65 Lario
« Reply #33 on: October 11, 2023, 03:23:08 PM »
Succinct, and to the point as usual Chuck. :grin:
Offline egschade
Re: 1985 V65 Lario
« Reply #34 on: October 11, 2023, 05:53:18 PM »
I have a cheapie compression tester that should do the job. What's a decent PSI, 150+?
« Last Edit: October 11, 2023, 05:53:56 PM by egschade »
1971 Honda SL350
Past Guzzis:
1985 LeMans 1000
V65 SP
V7 III Stone
V50
Griso 1200SE Tenni
Breva 1100
EV Touring
Re: 1985 V65 Lario
« Reply #35 on: October 12, 2023, 05:41:47 AM »
The point being.. if it has dropped a valve etc. there won't be *any* compression on that side. If you have 2 good heads you'll need to overhaul them anyway so a compression reading is a moot point at this time.
Offline egschade
Re: 1985 V65 Lario
« Reply #36 on: October 12, 2023, 07:10:55 AM »
Ah, got it. Thanks for the advice.
1971 Honda SL350
Past Guzzis:
1985 LeMans 1000
V65 SP
V7 III Stone
V50
Griso 1200SE Tenni
Breva 1100
EV Touring
