I’m still waiting to hear a story of an engine failure caused by using “the wrong oil.” Especially on a motorbike, which in most cases won’t see more than 100-200k miles of actual usage. Wet clutch slippage, sure, but a seized engine? Likely not.
but seriously folks, unless you are extreme or racing, almost any oil is good enough as long as it is new and fresh and close to correct weight. Even multi-weights are over rated unless you park outside ride in the winter in the North.
