Author Topic: Storing on side stand  (Read 2115 times)
Offline Dabrucru
« on: July 05, 2020, 03:12:37 AM »
Hi all
I dont post that much, sorry I just read (and learn) but i have this question about storing my 13 Racer. I m noticing that when its cold the right valves keep making this tikking noise for about 10 minutes, than the sound stops. When I asked locally someone told me that that s because I store the bike sideways, (side stand since my bike is not fitted with centre stand) and the right cylinder will empty itself from engine oil, hence the tikking noise. Which in my little knowledge it makes sense. So my question is: do I need a centre stand? Am I doing damage to the valves? And if I infact need a centre stand, is there variations for the v71 models ,since the racer a slightly more swept exhausts.
Thank in advance
David
Offline stephenm
Re: Storing on side stand
« Reply #1 on: July 05, 2020, 05:45:51 AM »
You can leave the bike on its sidestand. You will not damage the engine. The cylinders are not full of oil. When you start your bike, you should be riding off within a minute or so. Engines warm up to operating temperature quickest under moderate loads, while being ridden. Idling cold engines for extended periods is not an effective way to warm them up. Listening to ticking noises is not a path to happiness.
Stephen
Offline Zoom Zoom
« Reply #2 on: July 05, 2020, 05:48:17 AM »
What Stephen said.
John Henry
Offline s1120
« Reply #3 on: July 05, 2020, 08:17:15 AM »
With a MG both heads are higher then the oil pan. Being leaned on the side makes one a tick higher... but both are up in the air and allowed to drain what little oil is up there. I have seen flat boxer engines seep oil past the rings on the low cyl before and smoke like crazy for a min or two.. maybe thats what they are thinking about.
Paul B
Offline alanp
« Reply #4 on: July 05, 2020, 11:20:06 AM »
The OPs issue is valid.  My V7II definitely ticks louder on the right side than the left.  I have no centerstand.  The ticking quiets down after about 10 minutes, just like the OPs bike.  It is still not clear to me why this is, or if it matters, but it is a thing.
BTW, this has nothing to do with valve adjustment.  I have adjusted mine several times, and it does not change the tick.
« Last Edit: July 05, 2020, 11:21:37 AM by alanp »
Niwot, Colorado
'16 V7II Stone - Black
Previous Guzzis
Offline Moto Vita
« Reply #5 on: July 05, 2020, 11:27:13 AM »
 So lean it against a wall on the right side and see if it makes a difference.
Offline dguzzi
« Reply #6 on: July 05, 2020, 12:06:06 PM »
The early flying brick BMW's were prone to collecting oil when on the sidestand. Smoke a bit then cleared after warmup. You can't be comfortable with a smoking BMW around a bunch of Brit bike guys!
'03 EVT
'87 Cagiva
'72 Commando
'71 Commando
'13 F150
'16 Mustang
Online Moparnut72
« Reply #7 on: July 05, 2020, 12:42:43 PM »
I could never understand why BMW didn't put the cylinders on the righthand side on the K's. The earlier twins did it too from time to time.  Who knows why BMW does some of the things they do.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline alanp
« Reply #8 on: July 05, 2020, 05:34:47 PM »
After reading this thread I have decided to try that.
Niwot, Colorado
Previous Guzzis
Offline Two Checks
« Reply #9 on: July 05, 2020, 07:22:41 PM »
Early GL 1500s did it so bad they hydrolocked.
1987 1000 SPII "Il Duce' II"
« Reply #10 on: July 06, 2020, 06:48:16 AM »
My Breva has been stored on the sidestand for the whole 17 years of it's life.
Doesn't affect the engine, trust me.  I certainly wouldn't go to the inconvenience of leaning it against a wall where it might decide to move and go down.
Offline TheHungarian
  • ‘13 V7
« Reply #11 on: July 06, 2020, 10:34:38 AM »
Mine clatters louder on the LEFT side when it's cold. Once it's good and hot (about 10 miles) it evens out and quiets down, although still a VERY loud valvetrain. I just adjusted valve lash too. No difference at all. I'm a new owner and finally getting used to the symphony. Or, maybe, cacophony?
Best,
Mike
I've owned (at one time or another):
1976 Yamaha MX125
1978 Puch moped
1985 Honda Nighthawk 700S
1993 Suzuki GSX750 Katana
1996 Honda VFR750
2013 Moto Guzzi V7 Stone
Offline Dabrucru
« Reply #12 on: July 06, 2020, 02:25:14 PM »
Thank you all for your replies. From what you posted it seem a normal and safe thing.
Offline Knuckle Dragger
« Reply #13 on: July 06, 2020, 09:57:17 PM »
Mine was awful.  Quite embarrassing at times, esp. in mixed (i.e. alternative branded) company.
Severus bastardis
