Are all ignition coils interchangeable?
Topic: Are all ignition coils interchangeable? (Read 1831 times)
dxhall
July 12, 2020, 07:23:16 PM »
I am wiring the Eldovert and have a spare pair of ignition coils from my ‘03 V11. Other than the obvious problem of finding or making the female pin connectors for the newer coils, is there any reason the newer coils wouldn’t work?
dxhall
Re: Are all ignition coils interchangeable?
Reply #1 on:
July 12, 2020, 08:54:39 PM »
Would I check ohms across the two posts of the coil?
Charles in Lake Charles
Reply #2 on:
July 13, 2020, 08:11:29 AM »
As I remember, the latter coils measure around .5 ohms vs original coils 3-5 ohms, not interchangeable.
TOYS:
1985 Harley FLTC, 1985 K100RT
2001 Lees-ure Lite Camper,
1988 Mercedes 560SL
Don G
Reply #3 on:
July 13, 2020, 01:58:12 PM »
What ignition system are you going to be running? In my Ambo-vert I went with single point distributor and a dual pole Harley coil (5 Ohm), runs just fine. DonG
Last Edit: July 13, 2020, 02:03:17 PM by Don G
Chuck in Indiana
Reply #4 on:
July 13, 2020, 04:08:14 PM »
No. <shrug>
Sasquatch Jim
Sidecar - Best drive by shooting vehicle ever
Reply #5 on:
July 13, 2020, 04:54:37 PM »
In a word, No.
Sasquatch Jim Humanoid, sort of.
Wayne Orwig
Reply #6 on:
July 13, 2020, 05:45:44 PM »
The ones for the ECU are probably short dwell time, low resistance, coils. Not likely to work with older long dwell systems.
