Author Topic: Valve spring shimming  (Read 1490 times)
Offline Stevex
« on: July 13, 2020, 05:52:53 AM »
I'm going to be sending my LM2 heads for refurb this winter. New valves, springs and collets and guides K lined with seats re cut.
Am I right in believing the outer valve spring length when refitted needs shimming to obtain a length of 36.7mm - 37mm?
How is an easy way to measure this accurately?
Offline lucky phil
Re: Valve spring shimming
« Reply #1 on: July 13, 2020, 07:20:15 AM »
Install the valve in the head without the spring and seat the retainer and collets after installing a spring shim on the head. Hold the valve closed and use a 6" caliper to measure between the spring shim and the spring seating face on the spring retainer then calculate the additional shims/s you will need of preferably a single thicker/thinner shim.
Ciao
Offline Stevex
« Reply #2 on: July 13, 2020, 08:26:58 AM »
👍Thanks. Les, that's  one pristine head you've got there.
« Reply #3 on: July 13, 2020, 08:53:05 AM »
Ciao
This ^^^
