I put new pads in my EV and the front master cylinder also needs rebuilt.
What's the problem that requires rebuilding it?
I use a nail in the hole at banjo and knock it out the big end. After cleaning assemble w/stacked plunger & lock ring is held in a divot no snapring. I use a deepwell socket to knock it back in, bang it home as you have piston compressed a bit. It's covered in all the manuals, too. Pretty much always been the same.
I looked in the EV shop manual and rebuilding the master cylinders isn't covered, that I can see.
