Author Topic: paint code assistance  (Read 3840 times)
« on: July 24, 2020, 04:55:48 PM »
I asked this before-got sidetracked-and mis-placed the info.  Oops.
I have a lovely red 2001 Jackal.  Whoever can provide the correct paint code I'd be most grateful.  I've looked around the wonder of the interweb buy several seem VERY close and I'm not sure which to order.
Thank you in advance.
Online Ncdan
Re: paint code assistance
« Reply #1 on: July 24, 2020, 08:56:17 PM »
King, I can’t  offer the paint code but a lot of more advance paint and body shops should be a able to use their special equipment to match the paint.
« Last Edit: July 25, 2020, 09:31:34 PM by Ncdan »
« Reply #2 on: July 25, 2020, 03:44:45 PM »
Yep.  I though I might make it easier, that's all.
Offline 80CX100
« Reply #3 on: July 25, 2020, 05:31:08 PM »
Hey KOF,    This is info that Mike Haven of MPH had posted a long time ago on some of the Guzzi OEM paint codes; I don't see your model listed, but it may match other models on the list.
     I also copied some links on the bottom for supplier paint code databases that I had snagged earlier from V11Lemans.com, some of the links may be dead/alive; of use or not. fwiw.
     I did read a lot of info that even with the proper paint codes, getting a match was not always easy,,, ie  different manufacturers, applied over different base & primer or top coats and time & aging can all affect the end result.
      Fyi fwiw good luck
      Kelly
Paint codes are a national secret. You wont be getting any calls back.  I secured this list a few years ago after much badgering. its incomplete, but all there is
COLOR CODES:
NORGE 1200
      BLACK - BASF GE22-9659
      RED - 5.4D.23441 AKZO NOBEL                                      <<pic29436.jpg>>   <<pic21654.jpg>>
      GRAY - (Embedded image moved to file: pic29436.jpg)
1200 SPORT
      BLACK - 5.4M.22705 AKZO NOBEL
BREVA 1100
      GRAY - 928XV374 PALINAL
      ORANGE - DS.08046 LECHLER
      WHITE - BIANCO DIAMANTE: SCHOCH: 610.PM02 ASCO-BASECOAT PERLATO
BIANCO
BREVA 850 2007
      GRIGIO EXCALIBUR (Grey excalibur) : SCHOCH 675 ALP11-1/3675-003560
GRISO 1100
      LGHT BLUE - DS02096 LECHLER
      YELLOW - DS02138 LECHLER
      ORANGE - ARANCIO SATINATO :SCHOCH 3610-010805 PALINAL 923MAT3
NEVADA I.E.
      GRAY - GRIGIO LUCE - DS02074 LECHLER (+ 928XV051 PALINI for fuel tank
stripe)
      BLACK - NERO GUZZI - 5,4M.22705 AKZO NOBEL (+ 928XH913 PALINI for
fuel tank stripe)
      RED - ROSSO DEL LARIO - 66051 LECHLER (+ 5.4M.22705 AKZO NOBEL for
fuel tank stripe)
      RED 06 - ROSSO LDS08040 LECHLER
      BLACK 06 - NERO GUZZI 929R486 PALINAL or 54M22705 AKZO NOBEL
      YELLOW 06 - GIALLO 08048 LECHLER
      WITHE-BLUE 06 - BIANCO MICA DS08042 LECHLER - BLUE MIDNIGHT: DS08039
LECHLER
BREVA 750
      BLACK - NERO OLLARE - 928 XH 913 PALINI or 57E80806 AKZO NOBEL
      GRAY - GRIGIO PIOMBO:  AKZO  57E 85804 or PALINI 928 XH 644 + TRASP.
LUCIDO 923 HS 90
      ROSSO BREVA (2001) - Palini 928 XH 900 + TRASP. LUCIDO 923 HS 90
      RED RACE- ROSSO GUZZI - 5.4D-23441 AKZO NOBEL
      BLACK 06/07 - NERO GUZZI - 54M22705 AKZO NOBEL
      LIGHT BLUE 06 - AZZURRO-  DS02096 LECHLER
      WHITE 06 - BINACO MICA - DS08042 LECHLER
CALIFORNIA 06
      RED -  ROSSO - LECHLER LDS08040
      BLACK - NERO PALINAL 929R486 or ARDESIA AKZO NOBEL 54 M 22.710
      WHITE/GRAY - BIANCO LECHLER LDS08040 / GRIGIO LECHLER LDS08043
      VINTAGE -  NERO PALINAL 929R486 or ARDESIA AKZO NOBEL 54 M 22.710
CALIFORNIA 07
      RED -  ROSSO - LECHLER LECHLER LS 66013
      NERO PALINAL 929R486 O ARDESIA AKZO NOBEL 54 M 22.710
http://www.qnetonline.nl/LESEW/SearchForm/Manufacturer
http://www.mgcn.nl/index.php/mg-paint-codes-dameijer-database-40
http://www.rsbikepaint.com/en-gb/colours.php#makeid=98&modelid=2919&prodyear=2001&colourscheme=8192
http://www.color-rite.com/
http://moto-guzzi.motoeuropa.it/moto/guzzi/Colori-moto-guzzi-1986.pdf
« Last Edit: July 26, 2020, 12:02:33 PM by 80CX100 »
2008 California Vintage
2003 V11 Lemans
1979 G5 & 1980 Lemans CX100
Offline Zoom Zoom
« Reply #4 on: July 25, 2020, 07:42:11 PM »
If it helps, it's the same red as the 2003 LeMans.
ZZ
« Reply #5 on: July 26, 2020, 09:41:27 AM »
Thank you, gentlemen!
