Author Topic: This one DOES have me stumped..  (Read 8074 times)
« on: July 25, 2020, 04:00:15 AM »
It’s the V85..
There are several ways this problem can manifest, but this is the one most worth telling about.
You’re riding along at any speed/rpm combination, but for my example it’ll be 100 kph in top gear on cruise control. With no intervention from wind gusts or alteration in slope, the bike will almost imperceptibly lose a small amount of power accompanied by an equally small roughness to the engine, exactly like a six that drops one cylinder. The cruise control will apply some throttle and so the 100 kph is maintained.
If you weren’t astute enough you’d not even notice, until the power kicks in again and everything is normal.
Again it’s as if you were on a six and you flicked a plug lead off and popped it back on after a couple of seconds. I have felt exactly the same symptom when encountering icing on carbed engines, a gentle loss of power and a sudden kick as it resumes.
Now this loss and resumption of power is fairly small but unmistakably present.
Also, if you flog the living tripe out of the bike, it will really get up and go (for an 850), it’s at it’s best when working hard. Also the yellow engine light illuminates and takes a while to go out.
Now it’s fair to say that for 95% of the time the bike is perfect, so I’m not looking at any introduced anomaly caused by altering the exhaust system or repositioning the O2 sensors.
This is intermittent and not connected to ambient temperature or fuel tank level...(poor venting, I have opened the fuel cap while riding and it made no difference).
I’m going to re examine the extensions I made to the wires feeding the O2 sensors to make sure there are no introduced faults. I recently rode home from Broken Hill to Creswick (750 km) and not a spot of trouble.
I also think I’ll replace the Iridium plugs, just in case there is a whisker on one and check the plug caps.
Now Beetle pointed in the direction of a TC issue..
That made me sit up and take notice, so I did an on board re calibration but the problem still persists, also I have selected off road mode where the TC disconnects, but the issue comes back from time to time..
Just for the record, what does a malfunctioning injector feel like? I have given it a dose of cleaner.
Ok guys....Your turn.
« Last Edit: July 25, 2020, 04:04:29 AM by Huzo »
Offline blu guzz
  • Loves to ride
Re: This one DOES have me stumped..
« Reply #1 on: July 25, 2020, 06:20:28 AM »
In my commute, I have some long straight, flat stretches where I ride just like that on cruise.  My bike is bone stock so I will have to see if I can perceive this.  If the bike has done so, it has not been obvious enough for me to notice so far in 7,500 miles, but I am pretty dense. If I feel it, I will add a post.
Blue Guzz
« Reply #2 on: July 25, 2020, 07:04:53 AM »
ok thanks
« Reply #3 on: July 25, 2020, 07:10:45 AM »
Is the V85 a single or dual plugged motor?
Offline nick949
    • Nick Adams Writing
« Reply #4 on: July 25, 2020, 07:17:29 AM »
Is it not possible that the computer detected that you were on a miniscule down-slope or road speed had edged up to 101kmh, and it adjusted to stay at your preferred speed?  The cruise on my Cavalcade does exactly that (except it probably feels a little more jerky) - being an old-tech, non computerized system.  You may be looking for a problem that doesn't really exist.  Perhaps??
Nick
Offline Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
« Reply #5 on: July 25, 2020, 07:20:13 AM »
Is it related at all to the throttle positioning? At particular throttle position and gearing/ highway speed, my V7II would suddenly and slightly lag in power until I opened the throttle a bit more. Dealership replaced the O2 sensor(s) and it’s been fine since.
« Reply #6 on: July 25, 2020, 07:24:11 AM »
Nick
Thanks for your interest in this everyone.
It’s independent of engine load or rpm, but for sure when at lesser power settings.
 Also you can feel a reduction in the smoothness of the engine as it happens. It certainly does feel like an uncommanded intervention by the TC, but for what reason if at all ?
« Reply #7 on: July 25, 2020, 07:37:34 AM »
That’s a bit like my observations... :popcorn:
« Reply #8 on: July 25, 2020, 07:45:41 AM »
Single
« Reply #9 on: July 25, 2020, 07:53:17 AM »
No, not as such.
It can happen at 80 kph in top gear or 110 kph in top gear, that corresponds to a different throttle setting.
It’s really quite random and independent of other influences it seems.
The first time it did it was just after washing, but that was not a cause apparently. There is definitely a slight roughness that manifests during the incident, so I feel that it’s one cylinder laying down slightly. If it were a TPS command, it would reduce power on both pots and remain smooth given that it has a single throttle body.
I wondered if I had a slightly sticking valve, but thought better of it given that a touch of throttle overcomes it instantly....(sort of).
« Last Edit: July 25, 2020, 07:56:31 AM by Huzo »
Offline Ryan
« Reply #10 on: July 25, 2020, 09:03:25 AM »
My Subaru does this when there is a downhill slope. It lifts to slow, then adds a little, lifts a little... It feels like a misfire, shivering through the car. I think the precise fuel injection and over-zealous desire to cut all coasting emissions exacerbate the issue. I had one spot on my commute (when I had a commute) where it bothered me enough to kick it off cruise. Does this happen in the same place?
Offline SIR REAL ED
  • uh.... it's personal....
« Reply #11 on: July 25, 2020, 09:33:42 AM »
It does sound like a finicky cruise control system.  I had a Ford pickup which would kick out of cruise control on the same down hill consistently, but was otherwise fine every other place.  I chalked it up to fluctuations in the Earth's Magnetic Field at that location.
I would expect cruise control on a two cylinder engine to be much less precise (more noticeable while adjusting) than cruise control on a four, six, or eight cylinder engine.
Also sounds like it could be a bit of water in the gasoline, or whatever the Hell they call it in Straya.
Try filling up at a different gas station, or dumping in a bottle of dry gas when you notice it.  With the addition of the dry gas, it should go away within a couple miles.
If you have been using ethanol, try non-ethanal gas.  Cheers Mate!
ps.  did it do this before the silveriztion of the bike?  Could be an associated attitude problem.......
« Last Edit: July 25, 2020, 09:36:49 AM by SIR REAL ED »
2019 Beta EVO 250
Online Chuck in Indiana
« Reply #12 on: July 25, 2020, 11:15:01 AM »
I'll go with that one.. but.. this is ringing little bells in my memory thingy. I think I've read of this somewhere else, too.
GeorgiaGuzzi
« Reply #13 on: July 25, 2020, 12:51:47 PM »
Moto Guzzi does not employ any cylinder deactivation systems do they? I know new Indians drop the rear cylinder while cruising to help reduce heat. And car manufacturers have gotten it so good it’s really hard to notice when the cylinders cut out and back on.
« Reply #14 on: July 25, 2020, 02:04:15 PM »
It does it whether you are on cruise control or not.
My initial example included cruise control because I thought someone would suggest I wasn’t holding the throttle steady.
Not the case.
I tried it in off road mode so as to de activate the TC and made no difference. Remember, the yellow engine light comes on and stays on for some time during this issue.
« Last Edit: July 25, 2020, 02:05:53 PM by Huzo »
« Reply #15 on: July 25, 2020, 02:33:30 PM »
I am wondering if I have contaminant in the TPS ?
I have watched a few clips on the topic and the symptoms of a malfunctioning TPS sound scarily similar. Being ride by wire, is the TPS in the throttle winding drum on the twistgrip, or down at the throttle body ?
Offline malik
« Reply #16 on: July 25, 2020, 04:21:58 PM »
Had that problem for years on the V7C, albeit a different animal. A slight miss at constant throttle, none on a positive or negative throttle, usually at 110 in top motorway cruising, and intermittent. Often 10,000km between occurances. I'd do something, it would seem to fix it, but it would come back. Early on, a clean airbox & a new air filter would seem to fix it. For a while. Eventually,  I buckled down and learned how to test the TPS with Guzzidiag. Found a flat spot starting at 3,400rpm. No such trouble since I swapped out the TPS. A mate with a Cafe Classic (bobic on here) had a similar problem - his was fixed by cleaning & lubrucating the insides of the TPS. I suspect the problem could have been identified with proper application of a voltmeter. Not saying that this is your problem. It could be, but there's all sorts of possibilities when black boxes are involved. Good luck, Huzo.
Offline lucian
« Reply #17 on: July 25, 2020, 04:33:31 PM »
are there any stored or active faults recorded in the obd?
« Reply #18 on: July 25, 2020, 04:42:33 PM »
Thank you Malik, encouraging to say the least.
« Reply #19 on: July 25, 2020, 04:43:32 PM »
I can’t check that myself can I ?
I can on the Norge..
Offline lucian
« Reply #20 on: July 25, 2020, 11:22:15 PM »
You can, but you"ll need to contact Lonelect and get a cable and download guzzidiag { please donate} and get the bikes opinion!    :popcorn:
Offline redhawk47
  • Traveler
« Reply #21 on: July 26, 2020, 12:45:10 AM »
You said that it happens at different speeds. Does it happen at different engine RPM? If it happens at the same RPM that is a clue, particularly if it is about 3800.
The ECU stores faults even after the warning light goes out. You can read the fault(s) with GuzziDiag. Don't go by just the name of the fault. Look up "OBD #" on the web for more information; often there are several possible causes.
Dan
Dan
Offline lucky phil
« Reply #22 on: July 26, 2020, 01:20:29 AM »
It’s the V85..
First thing I'd do is use Guzzi diag and disable the closed loop setting for the injection system and see if that helps. Seems the issue is all at steady throttle where the closed loop has it's effect.
Ciao
Ciao
« Reply #23 on: July 26, 2020, 01:49:25 AM »
Followed Beetle’s advice there and will load Guzzi Diag.
New territory for me, but here goes..!
« Reply #24 on: July 26, 2020, 01:51:28 AM »
Dan
It appears to be random in it’s nature mate.
More often than not at gentle throttle settings, but not exclusivley so. Thank you for your interest though, it’s really helpful to me..
« Reply #25 on: July 26, 2020, 01:52:34 AM »
Ciao
Ciao
I’ll keep that in mind also..
Thanks.
« Reply #26 on: July 26, 2020, 05:55:48 AM »
What? You are a high mileage modern Guzzi Guy and you don't have Guzzi Diag? <shaking head and shuffling off>
« Reply #27 on: July 26, 2020, 06:18:17 AM »
Never needed it..
I have a Beetle map loaded by Pete Roper who is a leisurely ride from me.
It’d be like you living next door to Captain Sullenberger and not asking advice on a B737 or Airbus A320.....!
Also my 185,000 k bike is a Norge....Damn perfect.... :thumb: :thumb:
I will however, redouble my efforts to grow a set and learn how to load and use Guzzidiag..
It’s past time.
« Last Edit: July 26, 2020, 06:19:58 AM by Huzo »
« Reply #28 on: July 26, 2020, 06:44:17 AM »
Back at the top of the page I asked if the ignition was single or dual plug on the V85
I wondered if the loss of a few HP could be one plug quitting for a second.
I have looked through all the reviews and none of them mention two plugs so I assume that is a red herring.
Sooner or later a question will come up about a wiring issue, so far I have not seen a wiring schematic for the V85.
« Reply #29 on: July 26, 2020, 06:59:26 AM »
It feels like it’s dropping “half a cylinder” or less.
It’s a single plug head.
Very similar to icing in the feel, gentle and very subtle loss of some power with a slight roughness, then instant regaining of performance.
I’m leaning towards TPS.
Is the TPS in the twist grip drum ?
