Smithswede good suggestion. Tom, the fuel pump and filter are under the seat. Should I insulate them anyways? Anyways, the rain just started in earnest so I’ll get started checking in the morning and post results. Thanks
Okay, fuel pump is getting power after kill switch is switched on. It powers up for initial prime, then has power while turning over and when running.When cool it started right up. Idled and runs well. After a trip up the driveway and on the way back down it got warmed up and promptly died. Fuel pump still has power when cranking over during non start. However, when I checked spark the left side spark plug has strong spark, arcing nicely on the crash bar. The right side spark however, has a very faint spark. No arcing, not bright, just a faint wee spark. I did purchase a very basic multimeter today. But I have never used one so further instructions for diagnosing this would be most welcome.Cheers, Robert
Thanks Wayne. When it gets warm enough for whatever to trigger it shuts down quick fast and in a hurry. Like I hit the kill switch. It doesn’t act like it’s leaning out before it cuts out. It pulls good then cuts out without so much as a by your leave! Quite annoying.
My money ($.02) is on the coil(s). Paul B
Where was your money on July 28th?Its very easy to jump on the band wagon now
Thats good for the secondary side, check between the pos terminal and neg terminal on the coil for primary side ohms. should be less than 3to4 ohms, then check them both again after it's warmed up or stalls. Paul B
You are correct, should be just a couple of ohms. Paul B
Okay, the resistance on the left hand coil (the one with lots of spark) is 7.8.Resistance on right hand coil is 8.5.Measured by positive feed attached at plug cap, negative feed to frame.
When warmed up and doing it’s non start, both sides of the coil show 0.00 ohms. When the leads touch the connector prongs it shows 0.02, the 0.01, then 0.00. The multimeter does not show open loop, which would be a 1 on the left side of display. Just saw your post Roy. Yes this is the cheapest multimeter. Me buying an expensive piece would be a waste on me currently.
It doesn't matter how cheap the meter is if it works, even a $5 meter can be reasonably accurate, the expensive meters usually have better leads and are safer to use on mains applications.Hey, you are getting some readings now, we'll have you a sparky in no time lol
I’m still waiting to hear if swapping coils moves the problem. Or if starter fluid keeps it running. I don’t think it is the phase sensor. Don’t think it would start and spark at all if that were bad.
