install airbox ?
Topic: install airbox ? (Read 1596 times)
bacongrease
Gaggle Mentor
install airbox ?
August 09, 2020, 07:50:53 PM »
Stone stock airbox installation?
How the heck do they reinstall that thing ? ? ? ?
Wayne Orwig
Re: install airbox ?
Reply #1 on:
August 09, 2020, 07:56:24 PM »
When I do a transmission or clutch job on those, I swear that the airbox takes 1/2 my time.
bacongrease
Gaggle Mentor
Reply #2 on:
August 10, 2020, 02:39:34 PM »
well, airbox is in the shitcan..
i'll run open stacks before I spend any more time on that POS.
fotoguzzi
vee git tooh soon oldt und too late wise -my Dad
Reply #3 on:
August 10, 2020, 02:41:23 PM »
You could try warming it with a heat gun to get it a little flexible? They do go in that space, I've done it a few times.
bacongrease
Gaggle Mentor
Reply #4 on:
August 10, 2020, 03:11:02 PM »
Any reccomendations to alternatives?
YUP... I will get pods or go without anything before spending another minute on this POS.
Last Edit: August 10, 2020, 03:12:22 PM by bacongrease
fotoguzzi
Reply #5 on:
August 10, 2020, 03:35:54 PM »
Uni pod filters but keep the long runners or suffer slight decrease in torq.
Last Edit: August 10, 2020, 03:37:12 PM by fotoguzzi
antmanbee
Reply #6 on:
August 10, 2020, 03:52:31 PM »
Bisbee
Gosling
Reply #7 on:
August 10, 2020, 06:59:37 PM »
Taking out and reinstalling the air box , to service the injectors, was the most The most frustrating , infuriating part of the job. It does go back together but the pipes must be right or they will leak and suck sand , etc. into the cylinders. Hope I don’t have to do it again.
94 R100R Mystic , 92 K75S, 98 EV, 17 Stelvio NTX
Wayne Orwig
Reply #8 on:
August 10, 2020, 08:11:45 PM »
But that huge airbox helps performance. Hard to beat it.
bacongrease
Gaggle Mentor
Reply #9 on:
August 10, 2020, 09:21:31 PM »
Quote from: antmanbee on August 10, 2020, 03:52:31 PM
What is that?
antmanbee
Reply #10 on:
August 10, 2020, 09:49:44 PM »
It is a UNI sock filter with an internal spring to keep it's form. I have been using them for decades. Just cut out the closed end and get an extra hose clamp and you are good to go. Oil it up with the uni oil and slide the spring over the velocity stacks and clamp.
About $14.
https://www.walmart.com/ip/Uni-U-802-Flex-Core-Sock-Filter-51mm-I-D-x-202mm-Length/735011602
Last Edit: August 10, 2020, 09:57:23 PM by antmanbee
bacongrease
Gaggle Mentor
Reply #11 on:
August 12, 2020, 08:21:37 PM »
looks great, I'm going with that. . where did you find a spring? what size.
antmanbee
Reply #12 on:
August 12, 2020, 09:46:48 PM »
The spring is included when you buy the filter. It is inside the foam. You need to carefully cut out a circle from the closed end of the sock filter.
I remove the spring temporaraly and put the foam in a plastic bag and oil the foam lightly and squeeze it so the oil is evenly dispersed.
Then put the spring back inside the foam and slide the spring and foam over the velocity stacks and clamp lightly.
install airbox ?
