Author Topic: I hate when this happens  (Read 3629 times)
Online LowRyter
« on: August 19, 2020, 05:37:33 PM »
Came over a rise, saw a small pot hole, felt a small bump and then a roar of exhaust.  I have no idea about fixing it.  I considered getting a floor jack and moving it back into place and then I saw the whole rear unit was bent out of place and the bracket broken.
« Last Edit: August 19, 2020, 05:44:37 PM by LowRyter »
Re: I hate when this happens
« Reply #1 on: August 19, 2020, 05:42:09 PM »
 Ducati Supersports aren't very good woods bikes  :shocked:
 Surely your guy in OKC can sort that .
Online LowRyter
« Reply #2 on: August 19, 2020, 05:48:24 PM »
I hope so.  I thought I could get into place with a flour jack.  Then I saw the broken bracket, hopefully that's a stocked part.  Or maybe Don can fab something.
Funny, I barely felt anything.  I think a chunk of pavement broke loose when I hit the small pot hole.
Offline lucky phil
« Reply #3 on: August 19, 2020, 06:14:44 PM »
What the hell has caused the massive distortion/dent in the cover on the side of the collector? surely not hitting the bottom of the collector on the road due to a pothole.Looks to me like impact damage to the collector/cat cover like you hit something large on the road, not a pothole. Anyway,how to fix? remove the muffler and collector assy and buy a new bracket and refit or try to refit and see what it's like. I'd also remove the belly pan and loosen off the header mounts and also inspect that area as well for damage, same with the rear header. Should be ok but after a hit like this the whole system may need to be loosened off and reassembled. At the very least checked for damage that's not so obvious. Don't just try and jack it into place. You'll also need to check the lambda wiring as well as it looks like it's been yanked off its clips.Oh and you'll need a new collector cover as well.
Ciao
« Last Edit: August 19, 2020, 07:25:44 PM by lucky phil »
Pizza Guzzi
« Reply #4 on: August 19, 2020, 06:49:05 PM »
Annoying to be sure but most importantly you stayed upright 👍
Offline leroysch
« Reply #5 on: August 19, 2020, 07:52:13 PM »
If you wind up getting unsatisfactory parts availability locally, check out ducatiomaha.com. I 'm getting a thermostat and coolant thermistor for my '95 Duck in <2 weeks with free shipping. The email trail once I placed the order stated the parts were shipping from Italy..which if true...is pretty amazing, especially since I had waited 5 weeks to get a BMW part from the Netherlands recently.
Get that thing back on the road!
'88 FLST
'95 Ducati 916
'04 V11 LeMans
'06 FLHX
'17 BMW R Nine T
'19 H2 SX SE+
'22 Pan American
'24 Pan American CVO
Online LowRyter
« Reply #6 on: August 19, 2020, 09:32:46 PM »
I saw a little pot hole.  It felt like a little pot hole.   Just a bump in the road.  Not worth making evasive action at 75 mph and it didn't feel like more than a small bump when I hit it.  Oh well.  The rear header in probably bent.  Perhaps it can be rearranged.
Online LowRyter
« Reply #7 on: August 19, 2020, 09:43:49 PM »
The bracket is $12 (looks like only one of two needed).   The flapper valve cover is $45.  That flapper valve cable has always been droopy, I never thought about it needing clips.
I have no idea if parts are available or back ordered.
Offline lucky phil
« Reply #8 on: August 19, 2020, 09:56:09 PM »
Although it doesn't really matter but looking at the damage and location to the side collector/cat cover I'm beginning to think that this damage was done before you took it on that ride and the small pot hole you hit just shook it totally off the front pipe. Had you left it parked somewhere public before your ride? Or navigated your way in a tight parking lot with wheel bollards or such. Its always nice to know exactly how something has happened so you can asses the forces involved and possible need to look for other damage.
Not trying to worry you or anything but I've seen plenty of exhaust system damage over the years from pot holes etc but nothing quite this bad. I've seen an 851 break its rear engine mount on the crankcase when the centre pipe hit the road on a massive pothole and it dented the pipe but didn't have this sort of result.
Ciao
« Last Edit: August 19, 2020, 10:01:52 PM by lucky phil »
Offline rschrum
« Reply #9 on: August 19, 2020, 10:02:10 PM »
+1 Ducati Omaha, good folks!
15 GRISO
21 streetfighter v4s
24 zx14r 40th anniversary
01 ZRX 1200R
74 Norton Commando
23 Bimota KB4
97 Ducati 916SPS
Central Iowa
Online LowRyter
« Reply #10 on: August 19, 2020, 10:07:17 PM »
Ciao
No.  Don't think so.  it was a great day to ride and I just went to the same shop that I usually deal with.  The local Guzzi shop.  I was setting up a time to get the maintenance minder reset on the dashboard on the Duc.  Then I was heading out to ride around the local lake and see if any riders were hanging out.  I think there was a rock or broken pavement in the pot hole.  Perhaps I thought it wasn't a pot hole but it was a rock? I dunno.  Just a small bump and the bike began to roar.
I was shocked to see the damage.  Our roads here are awful.  You get a feel on when to dodge a hole or drive through it.  There was no hard jolt.  No big deal, then RRRRRRRRRRRRR.
Believe me, since everything is attached to the engine, it's crossed my mind that I might have broken something to total the bike.  I hope not but I have $1000 deductible on it.
« Last Edit: August 19, 2020, 10:11:55 PM by LowRyter »
Offline Motormike
« Reply #11 on: August 20, 2020, 04:57:21 PM »
But I bet it sounded great!  Just think, a lot of Ducati riders pay big money on full race systems to get that sound!
Offline tazio
« Reply #12 on: August 20, 2020, 05:15:42 PM »
Not implying bike wasn't set up correct for your weight, though I wonder if a severely  backed-off pre-load may had contributed (or broke linkage)?
Just thinking out loud.
1967 Kawasaki 650 W2TT
1966 Triumph Bonneville
GeorgiaGuzzi
« Reply #13 on: August 20, 2020, 05:49:38 PM »
I tend to agree that it was previously damaged and the pothole just jarred it loose. A co worker hit a pothole here in Atlanta in a company truck that had been previously repaired. The pothole knocked the bumper halfway off the truck!
Online LowRyter
« Reply #14 on: August 20, 2020, 05:55:38 PM »
It sounded cool for about the first 3 minutes.  After that, not so much.  Even with ear plugs and helmet.  And to be honest, the high revving little 937 engine just doesn't have the "kick you in the gut" like my V11 Sport with Mistrals.   I much prefer my Duc with the stock exhaust IN TACT, it spits and rumbles but at much better level with the muffler.
I just learned that the tupperware was also broken the attachment.  That's a $500+ piece of plastic.  I'll take it to my body guy and see what he says.  He did a good job on all the fragile green plastic on the Sport.
Online LowRyter
« Reply #15 on: August 20, 2020, 06:06:31 PM »
I didn't hit anything prior to that to indicate that there could be earlier damage.  I usually do a once over on the bike every time I ride.  I put it on the rear stand and check the chain and clean the bottom parts and wheels.  I recently polished the smashed muffler cover and have taken it apart to clean the flapper valve.  So I don't believe for a second that there was previous damage.
Funny thing.  I was ordering the brackets and sundries from the local dealer.  As soon as I said what had happened, the guy on the phone said, "I know exactly the pothole you're talking about.  They fill it up all the time."
Having said all that.  I am just amazed the bike just glided over it when I see the damage.
Online LowRyter
« Reply #16 on: August 22, 2020, 08:45:59 AM »
Contacted them.  Appreciably all parts are shipped from Italy.  It takes a week to get them here.  At least that's what Omaha and my local shop told me.  So I've ordered a $125 worth of fasteners and it should be here next week.  I hope to get the fairing repaired by my body guy that's done some plastic repair on my Sport.
Online LowRyter
« Reply #17 on: August 29, 2020, 02:05:06 PM »
I got his in the mail today.  It's a $1500 Ducati muffler.  Luckily, many riders toss them and put on aftermarket pipes and reflash, so for $1500 those guys get another 4HP.
So from Ebay, $72 w/shipping ($40) and tax.  <Guzzi Content>
Online Chuck in Indiana
« Reply #18 on: August 29, 2020, 02:27:01 PM »
He shoots! And he scores!!  :grin:
Offline lucky phil
« Reply #19 on: August 29, 2020, 08:59:21 PM »
Good deal. It does make you wonder how stupid people actually are. The OEM muffler is worth about nothing so why sell it after upgrading to a sports system. I never sell the standard exhaust, so if I ever need to sell the bike unless the buyer wants to do me a deal on the aftermarket system it gets sold separately. I'm not going to give away a $3500 full titanium exhaust for instance just so I can get maybe $120 for the original system.
Ciao
Online LowRyter
« Reply #20 on: September 04, 2020, 02:19:46 PM »
Unfortunately the front header pipe is cracked.  Couldn't be welded.  Ordering another take off piece from Ebay.  Another $140 from the Denver Aprilia shop.
Online bad Chad
« Reply #21 on: September 04, 2020, 03:53:40 PM »
When your fu%*&@#$, I mean dating a high priced Italian beauty you have to expect these sort of things.  So nice to be able to get back on track so cheap!
1988 YX600 Radian
Online LowRyter
« Reply #22 on: September 19, 2020, 02:15:47 PM »
Some good news.  This one is back in service.
GeorgiaGuzzi
« Reply #23 on: September 19, 2020, 02:51:25 PM »
When you’ve been dealing with issues on your bikes like you have, that’s not good news, it’s MOST EXCELLENT news dude!!!
Offline lucky phil
« Reply #24 on: September 19, 2020, 06:00:09 PM »
Very good :thumb:
Ciao
Online LowRyter
« Reply #25 on: September 20, 2020, 01:25:12 PM »
Thanks.
