Author Topic: Indicator issue  (Read 884 times)
Offline Guzzi_750nevada
Indicator issue
« on: August 25, 2020, 04:25:58 AM »
Hi there guzzi guys...
I've got an issue with the electronics on my moto guzzi 750 nevada classic I.E 2008, the issue consists of the indecators not working at all, I've checked all fuses and their fine all wires seem to check out as fine. Even the hazard lights work find so I'm not sure if it's the switch its self or something else.
If anyone could provide any help and assistance to what could be the root cause of this problem is?
My thanks.
Re: Indicator issue
« Reply #1 on: August 25, 2020, 06:10:37 AM »
Welcome to WG. I couldn't find a wiring diagram, but *I think* the turn signals and hazard lights are powered by a different fuse.
At any rate, It's probably either at the switch itself or a fuse.
Offline Zoom Zoom
Re: Indicator issue
« Reply #2 on: August 25, 2020, 06:48:08 AM »
I'm assuming you mean the turn signal indicators, right? Or do you mean all the dash indicators?
If we're talking turn signals, are they working and you're not getting an indication on the dash?
If they are not, is there a turn signal flasher can on the bike? If so, that would be the next thing I would look at if the signals are not working.
John Henry
