Author Topic: Convert 76  (Read 1968 times)
Convert 76
« on: August 27, 2020, 03:16:57 AM »
A 76 Convert, anything in particular to worry about?
I have longed to try a convert for a while now since a good friend keeps raving about his "Magic Carpet Ride"
Offline 80CX100
Re: Convert 76
« Reply #1 on: August 27, 2020, 03:42:00 AM »
Hey Roy,     Some of the Converts had the stamped steel flywheel which was a weak link, but other than that it's basically the same as the G5, iron bore etc.
     Dave Richardson mentions it in guzziology and has a diagram showing how you can tell the difference looking through the timing hole.
     I know lots of people have had the stamped flywheels reinforced without issues,fwiw.
     I passed up a low mileage, low priced Convert barn find years ago, because of the flywheel issue, I still regret that one,lol.  :weiner:
     Kelly
2008 California Vintage
2003 V11 Lemans
1979 G5 & 1980 Lemans CX100
Offline nick949
    • Nick Adams Writing
Re: Convert 76
« Reply #2 on: August 27, 2020, 06:44:26 AM »
Not trying to influence you or anything Kiwi_Roy, but................ ......
https://youtu.be/PIat391vi2A
Good luck,
Nick
Re: Convert 76
« Reply #3 on: August 27, 2020, 08:45:49 AM »
Two possible failure points that need to be addressed IMO:
1. flywheel - early stamped steel bowl can fracture... or not. Dave Richardson attributes failures to engine/trans misalignment. I wasn't taking a chance and installed the heavy machined flywheel.
2. hex piece that drives the ATF pump - the pump is driven off the end of the cam by a 6 mm x ~ 30 mm hex section shaft. The "socket" it fits into on the pump coupling in early pumps is only 8mm deep, later pumps it's ~ 12 mm deep. My hex piece rounded off and left me stranded in Punxsutawney, PA. I upgraded to the later coupling with 12 mm socket, but the hex piece still fit loosely in that and the end of the camshaft. I had a custom hex piece made that is 6.2 mm and that fits snug in both the cam and pump.
Offline Markcarovilli
Re: Convert 76
« Reply #4 on: August 27, 2020, 02:12:15 PM »
Kiwi Roy
they do grow on you and Charlie has it covered for now.  Like sitting back on an old comfy couch and feeling the breeze....
Mark
Offline dxhall
Re: Convert 76
« Reply #5 on: August 27, 2020, 02:56:23 PM »
If you buy one, you’ll be eligible to attend the International Convert Meet next spring (date and place to be determined, but I’m thinking the Banff area in May).  I’ll be taking the Eldovert.
Offline ray bear
Re: Convert 76
« Reply #6 on: August 27, 2020, 06:45:07 PM »
Hi Kiwi Roy, only had a convert for less than a year but find it a very rewarding bike to ride and a keeper  . I also have an 850 Eldorado and a V7 sport  as comparison . However I would reccomend putting a master gauge on the ATF pump and check for pressure as my bike had been fiddled with by last owner and the spring seat (12 15 07 00)  that sits behind the spring and acorn nut had been left out and I was only able to get a maximum of 5 psi ATF pressure as the pump was bypassing back to the tank. I  was unable to find the correct part so experimented using a selection of varying sized ball bearings and also varying thicknesses of aluminium sealing washers on the acorn nut  to attain the correct spring pressure /oil pressure of somewhere around 25 to 30 psi that the converter requires and found that by increasing ball bearing sizes by only thousands of an inch I could raise the pressure dramatically and the first ball I used I was getting 65psi and after much fiddling and also having to linish the end of the spring and the alloy sealing washer I finally ended up with 28 psi. What I am saying is that a bike  with a well used alloy sealing washer on the acorn nut  that someone may have overtightened  may increase fluid pressure well above the makers spec and put undue stress on the 6mm drive key resulting in a premature failure  of which I read about in this forum  every nown and then . Ask Charlie. Also not too many revs for the first 10ks as I left my master gauge on the bike for a few rides and from cold it was easy to get pressure up around 40 to 50 psi  till fluid had warmed . So a spirited start to your riding day may well put a lot of load on the tiny pump drive.. My two bobs worth and Im sure others will chime in later .
73 V7 sport
73 Eldo police special
68 BSA rocket 3
74 Norton Commando
78 Honda CBX 1000
47 HRD vincent Rapide
XT 500 Yamaha
Offline dxhall
Re: Convert 76
« Reply #7 on: August 27, 2020, 06:54:36 PM »
Did you make a permanent installation for the pressure gauge?  I’d like to see how you did it.
Offline JayDee24ca
Re: Convert 76
« Reply #8 on: August 27, 2020, 09:43:39 PM »
Roy, as you know from your adventures with the Eldo and others, there is nothing on a bike that cannot be fixed. Tin flywheel? Worn drive key? Weak ATF pump? Peanuts for a guy like you.  :grin:
JD
'74 Nuovo Falcone
'79 Convert
79 G5
the rest are all gone.....
Re: Convert 76
« Reply #9 on: August 28, 2020, 12:13:06 AM »
JD
John,
       Its your fault I want a Convert in the first place, you and your "Magic Carpet Ride"
I have a line on a couple now.
Re: Convert 76
« Reply #10 on: August 28, 2020, 12:14:08 AM »
Thank-you gentlemen for all the tips.
Roy
Offline ray bear
Re: Convert 76
« Reply #11 on: August 28, 2020, 12:27:24 AM »
Hi dx , yes I have set it up semi permanent using a longer banjo bolt an a AF banjo fitting , put a blanking cap on the AF fitting and can attach to it whenever
facebook sign photo
« Last Edit: August 28, 2020, 12:29:51 AM by raybear »
73 V7 sport
68 BSA rocket 3
74 Norton Commando
78 Honda CBX 1000
XT 500 Yamaha
Re: Convert 76
« Reply #12 on: August 28, 2020, 07:07:13 AM »
facebook sign photo
I must remember that one  :thumb:
Online Bulldog9
Re: Convert 76
« Reply #13 on: August 28, 2020, 03:07:38 PM »
Love my Convert. Not a 'canyon carver' but a wonderful ride.
Others have covered the 'worrysome' bits.  I have the light drive plate so I sourced a spare heavy and light flywheel and starter ring for' just in case'  AFAIK both the original flywheel and allen key in the drive are original to the bike and never messed with or failed.
MGNOC#23231
Offline mtiberio
    • TiberioRacing
Re: Convert 76
« Reply #14 on: August 29, 2020, 05:52:12 AM »
 "Magic Carpet Ride"
I believe I was the first to coin that term...
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
Offline JayDee24ca
Re: Convert 76
« Reply #15 on: August 29, 2020, 10:24:31 AM »
I wasn't sure who originated the term, Mike, but it sure is an accurate description. I think I first heard it from Bill Bruno, and it immediately struck me as fitting. Kudos to you, then.
JD
'74 Nuovo Falcone
'79 Convert
79 G5
Offline Kiwi Dave
    • Guzzi Gander Ltd
Re: Convert 76
« Reply #16 on: August 29, 2020, 04:16:28 PM »
I have the Moto Guzzi workshop manual for the V-1000 I-Convert, and a parts manual for the same.  I think they're genuine originals.
A small donation to the charity of my choice will induce me to part with them, as I can never envisage me ever owning another one.
