Bike Builds, Rebuilds And Restorations Only
kballowe
UK Andy Sidlow Framed Endurance Racer
Pages:
3
4
5
Topic: UK Andy Sidlow Framed Endurance Racer (Read 177902 times)
cliffrod
AC Button II
Re: UK Sidlow Framed Endurance Racer
Reply #90 on:
October 18, 2024, 09:33:51 AM »
Love seeing the progress. Thanks for the new pic!
1973 V7 Sport "Now THAT'S a motorcycle!"- Master Sculptor Giuliano Cecchinelli
Groover
If it ain't broke, I'll break it.
Reply #91 on:
October 18, 2024, 01:18:49 PM »
Pearl green. Sharp! Can't wait to see more!
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Mayor_of_BBQ
Instagram: @Mayor_of_BBQ
'Ever thus to deadbeats, Lebowski'
Reply #92 on:
October 21, 2024, 10:08:01 PM »
just went back thru this thread again! damn nice work. This a very cool project
Turin
Reply #93 on:
December 04, 2024, 11:38:21 PM »
Crankshaft is back from balancing. Marine Crankshaft inspected, magnafluxed, dynamic balanced the crank and micro polished the journals. $240.00 with one way shipping back home. I had wanted more exotic work, but Marine Crankshaft wasn't on board with going nuts. I can appreciate being told why and when I'm wrong, especially when it saves money. I have a windage tray/sloppage plate going in too.
here are some pics and the piston rod bobweight card.
5 sided dice
Last Edit: December 04, 2024, 11:52:33 PM by Turin
1985 Sidlow Guzzi
larrys
Reply #94 on:
December 11, 2024, 01:09:05 PM »
They drilled the hell out of the weights. What % overbalance did they set it to?
Larry
'13 Monster 1100 EVO
'95 Cal 1100
'68 Bonneville
MGNOC 7248
Turin
Reply #95 on:
December 15, 2024, 02:40:37 PM »
I have no idea to be honest. sent them everything and told them what I was after and a wishlist including knife edging, polishing etc. Marine Crankshaft poo-pooed most of my ideas and only did what they though was needed. Probably saved me a good chunk of change too.
The crank still heavy. 20 lightening holes is like scraping a few cubes off of an iceberg.
1985 Sidlow Guzzi
Antietam Classic Cycle
Happily stuck in the past.
Reply #96 on:
December 16, 2024, 08:25:04 AM »
If you add up all of the weights you get 1421 grams. Multiply that by 52% (a common balance factor for Guzzi engines) and you get 738.92 which is close to the 743.6 bob weight used. 52.3% gets you even closer - 743.18.
Turin
Reply #97 on:
December 23, 2024, 12:52:09 AM »
Engine is starting to go together. Here are pics of the Trankontinental clutch/flywheel assembly. The entire set up weighs 7.54 lbs.
If you look down into the motor, you can see the aluminum windage tray and the filter poking through it. Tom Hull machined an additional hole into the rear left side of the windage tray to ensure all of the oil drains back into the pan and doesn't pool on top when the bike is parked.
Last Edit: January 25, 2025, 02:54:46 AM by Turin
1985 Sidlow Guzzi
Turin
Reply #98 on:
January 25, 2025, 03:13:53 AM »
The engine is together. Squish is set at 44 thou, it may tighten up a tiny bit after it's gone through a few heat cycles and re-torqued. Piston and valve clearance is a none issue. I went with the mystery cam that came with the pile of parts I bought 10 years ago. It has slightly less lift than a P3 with a ton of duration. It should rev like a two stroke ( I'm hoping)
here is a shot down the gullett
here are some "art shots"
guilt poems by famous poets
Last Edit: February 01, 2025, 04:39:22 PM by Turin
1985 Sidlow Guzzi
Turin
Reply #99 on:
February 01, 2025, 04:25:33 PM »
Tranny Torn down, bearings to be replaced.
1985 Sidlow Guzzi
Turin
Reply #100 on:
February 07, 2025, 12:38:00 AM »
Engine, tranny, frame
Last Edit: February 08, 2025, 01:54:42 PM by Turin
1985 Sidlow Guzzi
Turin
Reply #101 on:
February 12, 2025, 10:07:51 AM »
Swing arm, Wheel.
1985 Sidlow Guzzi
Turin
Reply #102 on:
March 07, 2025, 12:22:40 PM »
Some further progress and a better look at the exhaust. 44mm headpipes.
1985 Sidlow Guzzi
Turin
Reply #103 on:
March 23, 2025, 07:22:40 PM »
It lives! First start up. carbs are as they came out of the box. needs tuning.
https://www.youtube.com/watch?v=o1L10dg8AMo
Last Edit: March 23, 2025, 07:49:41 PM by Turin
1985 Sidlow Guzzi
Ratso88
Gosling
Reply #104 on:
March 24, 2025, 06:13:02 AM »
Sounds like she wants to run!
Nice job.
Turin
Reply #105 on:
April 04, 2025, 12:35:01 AM »
paint work almost done. looks a little dark in the pictures
1985 Sidlow Guzzi
Turin
Reply #106 on:
April 18, 2025, 01:46:33 AM »
Painted... number plates are being re-done. looked crappy. My painter added extra small flake with the big stuff. I'm waiting on the brake caliper brackets. and the seat pad. 90% there.
1985 Sidlow Guzzi
Ratso88
Gosling
Reply #107 on:
April 21, 2025, 08:45:28 AM »
Very nice!
Especially digging the metal flake
Turin
Reply #108 on:
April 27, 2025, 03:17:03 AM »
here are some more with the revised # plate taped off.
1985 Sidlow Guzzi
Turin
Reply #109 on:
May 03, 2025, 02:43:28 PM »
Floating rear brake bracket and caliper, front brake brackets and calipers
1985 Sidlow Guzzi
Turin
Reply #110 on:
May 08, 2025, 01:59:21 PM »
Panels re-painted.getting close.
1985 Sidlow Guzzi
cliffrod
AC Button II
Reply #111 on:
May 09, 2025, 08:09:02 AM »
Really enjoying the pics & progress! Thanks for posting, Turin.
Turin
Re: UK Andy Sidlow Framed Endurance Racer
Reply #112 on:
May 23, 2025, 06:17:23 PM »
Here's a vid and pics. Almost done! I have to weigh this thing. It is incredibly light.
https://www.youtube.com/watch?v=qIobZFSiPzI
1985 Sidlow Guzzi
Turin
Reply #113 on:
May 23, 2025, 06:19:56 PM »
1985 Sidlow Guzzi
Turin
Reply #114 on:
May 23, 2025, 06:54:47 PM »
1985 Sidlow Guzzi
cliffrod
AC Button II
Reply #115 on:
May 23, 2025, 08:24:24 PM »
Hot damn- That’s really bitchin!
Turin
Reply #116 on:
May 23, 2025, 08:38:09 PM »
Thanks! it moved under it's won power for the first time today.
next steps
retorque the heads
adjust jetting
check the nuts and bolts
Shorten the clip-ons. I'm taking 2 inches off of each bar.
Then break in. I'm optimistically
hoping
for 80- 90 rear wheel ponies. It feels extremely light. I'm guessing 450 lbs. with a full tank.
1985 Sidlow Guzzi
Turin
Reply #117 on:
May 25, 2025, 12:38:05 AM »
flipped the tarrozzi clip-ons to bring them closer and shortened the bars on each side. The narrow tank makes the wide bars look wider than they are. The fork angle sits at 23.5 degrees. The leverage is needed. Installed lemans bar ends and one bar end mirror to keep things legal.
further tweaks to be done
1985 Sidlow Guzzi
Turin
Reply #118 on:
June 06, 2025, 12:22:15 AM »
Had my first test ride tonight. The bike feels very tall, even though it uses lemans 1000 forks and triples. Handling is alien and unguzzi like, part of that is the 23.5 degrees of rake and 3 inches of trail, and the rest may be due to the lack of weight. (I'm looking for a scale, will report back).
On the highway the motor is eerily smooth, almost like an 850. Not much engine braking to speak of. I won't be taking it past 6000 rpm for the first 1000 miles. After that, I'll give her the beans. It should make power to 9k. (I can hope). So far so good.
Last Edit: June 27, 2025, 08:20:50 AM by Turin
1985 Sidlow Guzzi
cliffrod
AC Button II
Reply #119 on:
June 06, 2025, 08:50:14 AM »
Great to hear about some road miles!
Pages:
3
4
5
kballowe
