Thanks again for all of the suggestions/input. I'm familiar with the misfiring sparkplug/cap problem, but never had a problem with the originals in the slightly-over 11k miles that my first engine lasted, so never got around to replacing with the NKG XD05F, which I bought shortly after purchasing the bike. Plug caps seem to be fully seated, and I'm not getting any discoloration where the cat is on the mufflers, so I assume that's not the problem. Injectors seem to be properly connected, at least as far as I can tell (I haven't lifted the tank off completely to check the rest of the plumbing/wiring... need to do this). I'm a bit spooked by the appearance of oil weeping from the left cylinder head/block articulation (top) as well, though know that heads need to be retorqued after the first 600 miles. I'm not keen on taking the bike back to the dealer for a variety of reasons (not the least of which, it's a 1.5 hour drive away!), so will keep poking around... thanks for the insight and nudges to keep digging!
Really? surely they uses an MLS gasket these days and not old style composites. Even the later 2 valve big block use an MLS head gasket. MLS dont require retorquing.Ciao
I can see you aren't that aware of the technical shortcomings of the modern mass produced engine/vehicle which is understandable if you're not directly involved in it or connected to people that are. This sort of significant mechanical issue is a common everyday fact across vehicle and even aviation manufacturers not some "one off" rare incidence. The average person just simple doesn't hear of it.Thats why you never buy the first model of anything, just to reduce your exposure. It doesn't mean you'll have zero risk as a lot of the time it's a "manufacturing defect" as opposed to a "design issue" but at least with a mature design you can largely eliminate the latter.Ciao..
I believe the engine problem in this thread s a result of careless production and or poor quality control on the bearings...Guzzi has been building very similar engines for half a century and none of them are exactly state of the art. Well the 4 vave engines were different and many suffered from cam and follower issues.
Yes a lot of the time it is down to quality issues at the factory and one off short term problems but as I said it's not at all uncommon. I've known lots of these issues over the years and quite a few of them are dealt with at the distributor level before the bikes are even sent to the dealer. Like un-crating one brand of brand new superbikes at the warehouse to re torque big end bolts or finish drilling cylinder head oil galleries or replace complete heads if necessary due to the damage caused therein. Replacing piston and barrel assemblies on warehoused bikes due to casting sand contamination in the transfer ports.The list goes on and on and the average customer is none the wiser.Ciao
Are you implying that new Harleys, Hondas and other mass produced machines are routinely serviced like you mention before delivery?
