Author Topic: Readdressing a handlebar issue  (Read 4419 times)
Offline Ncdan
« on: September 17, 2020, 01:03:44 PM »
Hey guys. A while back I ask what’s the best and cheapest way to get the bars a little higher and back on my 02 California Stone. One of the guys here offered a set of bars off a 1400 tourer and we thought they were the same as a Stone. However when they got to me I measured them and it appears that what we were measuring in inches came out different in millimeters.
The Stone has 30mm bars and the 1400 has 28mm bars, so I’m back to where I started.
Can anyone tell me where or who makes 30mm diameter bar risers. Thus far I’ve been unable to locate anything in that size. I spoke with the rep at ROX accessories who told me there is no such animal out there:(
Thanks in advance!
Dan.
« Last Edit: September 17, 2020, 01:11:11 PM by Ncdan »
Online Tom H
Re: Readdressing a handlebar issue
« Reply #1 on: September 17, 2020, 01:27:08 PM »
If you like the bars you were sent. Make a shim to make them fit. Beer cans always work well, cut a strip the width of your clamps and wrap around the bar until thick enough.
As I mentioned, ROX as well as others on for instance Amazon sell risers. Find the one that closest matches your 30mm bar and shim or grind out where you need to.
Good luck,
« Last Edit: September 17, 2020, 01:33:05 PM by Tom H »
Offline Ncdan
« Reply #2 on: September 17, 2020, 01:46:33 PM »
Good luck,
Thanks Tom for your response.
I really don’t much like the idea of shimmering with the slick material of a can as the ridges are cut into the steel of the bars for a reason, which it to keep them from slipping under pressure. I would rather be able to find the appropriate 30mm risers or bars.
GeorgiaGuzzi
« Reply #3 on: September 17, 2020, 01:49:53 PM »
Dan, I’m about to change out the bars on my Quota. My bars that are going on are 30mm. If I remember right that works out to 1.18 inches which is close enough to 1 1/8” for me. I ordered a pair of riser adapters that are supposed to work. They have shipped and when they arrive I will take measurements and photos for you. 1 1/8” bars are referred to as “fat bars” if that helps you search. Lots of late model cruisers use them.
Offline moto-uno
« Reply #4 on: September 17, 2020, 01:53:16 PM »
 Punching numerous small holes in the shim metal and then adding loctite makes for a pretty secure H/bar locking .  Peter
Offline Ncdan
« Reply #5 on: September 17, 2020, 01:59:28 PM »
Thanks Bob👍
Online Moparnut72
« Reply #6 on: September 17, 2020, 02:09:03 PM »
If you use Locktite use the green. Just make sure you have them where you want them. The green is sleeve retainer.  It will be hell to take it apart.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline Ncdan
« Reply #7 on: September 17, 2020, 03:32:03 PM »
kk
Problem with that is most of the time it takes me several rides to get the bars just right for my liking.
Online Vagrant
« Reply #8 on: September 17, 2020, 04:05:34 PM »
should be standard 7/8".
I put a set of superbike bars with some custom made risers/barbacks made for a ST1100 on it. the bike felt just like a smaller Electra glide classic. they are now on a 2001 EV. so much better bend than a stock bar.
Offline BillinPA
« Reply #9 on: September 17, 2020, 04:13:52 PM »
Another option is to lift the bottom half of clamp from the triple tree. I have a set of nice aluminum risers with a longer bolt to accomplish this.  I have heard of people using the longer bolt and a pair of matched sockets to do the same.
Offline moto-uno
« Reply #10 on: September 17, 2020, 04:19:03 PM »
  ^ +1 , Peter , was a common mod on Harley's .
Offline Ncdan
« Reply #11 on: September 17, 2020, 04:24:57 PM »
The Stone bars are 30mm not 7/8”
1400 models are 28mm
Offline Ncdan
« Reply #12 on: September 17, 2020, 04:28:24 PM »
Yes, I can raise the bars by using deep well sockets or for less height use standard 1/2” drive sockets and in chrome or flat black. However I don’t think I can get the bars back enough using this method.
Online Tom H
« Reply #13 on: September 17, 2020, 04:53:30 PM »
I think 28mm might be close to 1 1/8". If you like the new bars, maybe HD risers with pull back would work for you?
Um....One question..... What size are the new bars where the controls go? S/B either 7/8 or 22mm. I don't remember what Guzzi uses. My old BMW is 22mm.
Offline Ncdan
« Reply #14 on: September 17, 2020, 05:17:22 PM »
I don’t think that will work Tom because of the taper at the end of the bars to a 7/8” size. Only Moto guzzi would do something like this😡
« Last Edit: September 18, 2020, 07:04:02 AM by Ncdan »
Offline Ncdan
« Reply #15 on: September 17, 2020, 06:13:14 PM »
Does anyone by chance have a set of clamps that’s made for 7/8” bars? I could change these two out and finding 7/8” bars are a dime a dozen. A set of buckhorns would work great for me.
Offline Caffeineo
  • Guzzi B00b
« Reply #16 on: September 17, 2020, 06:50:51 PM »
Not trying to add more challenges......but the "bar backs" I got for my Bobber Sport that seem to fit every other bike made......did not fit.  :angry:
The distance between bolt holes was off. Way off. I got some generic Rox Risers and that did the trick.
2022 Moto Guzzi V85
2023 Husky TX300
2020 KTM 500 XCW
Offline Ncdan
« Reply #17 on: September 17, 2020, 07:29:44 PM »
No problem Caff but I must admit at this point I’m not sure what option to use as none seem to be a simple take off, put on, option 🤔
« Last Edit: September 17, 2020, 11:04:56 PM by Ncdan »
Online John A
« Reply #18 on: September 17, 2020, 09:43:30 PM »
Check parts books.  On a 99 EV or Bassa you could get either 22mm or 30mm bars.  All you need is the appropriate clamps, the risers are the same
« Reply #19 on: September 18, 2020, 09:56:57 AM »
I'd be off to the machine shop and have what I wanted made.  Overkill most likely.  just like I like it!
Offline John Croucher
« Reply #20 on: September 18, 2020, 11:02:59 AM »
While you are at it, check the bushings in the triple tree.  Turn the bar to full stop, right and left.  Continue pushing and you will see that the bar continue to move/twist another inch or more from the sloppy rubber bushings.  I removed mine and replace them with a solid bushing.  Giving better control of the bars.
I also filled the bars with lead balls used in muzzle loader gun, dipped in silicon sealant to add dampening.  A little extra weight, but it made the buzz and vibration go away significantly.
Offline flyerstill
« Reply #21 on: September 19, 2020, 07:41:45 AM »
I moved my bars back and up with a piece of Walnut wood on a 03 EV. One advantage of wood is you can make it to suit your needs. Some have doubted the use of wood. The only way the wood will fail is for you to be in a wreck or to catch the bike on fire.
Offline Caffeineo
  • Guzzi B00b
« Reply #22 on: September 19, 2020, 07:48:32 AM »
Can you post a pic of this???? I do like the idea and think it wood look great. ;)
2022 Moto Guzzi V85
2023 Husky TX300
2020 KTM 500 XCW
Online Vagrant
« Reply #23 on: September 19, 2020, 08:40:18 AM »
   Nope mask did it on the versus 1000 in 2015 go look and measure one as aftermarket bars for it might work for u
Offline Ncdan
« Reply #24 on: September 19, 2020, 01:02:42 PM »
Not sure what this is V, could you elaborate a little?
« Last Edit: September 19, 2020, 01:04:46 PM by Ncdan »
GeorgiaGuzzi
« Reply #25 on: September 19, 2020, 02:49:27 PM »
Versus is a Kawasaki I believe, like a Suzuki SV650. And it’s a popular mod for metric adv bikes. The pro taper bars I’ve got for my Quota are exactly like this. It does away with the need for a cross brace. My bars are 30mm at center, 22mm (7/8)at ends. It means I don’t have to change out my 22mm controls.
Offline Ncdan
« Reply #26 on: September 19, 2020, 06:40:29 PM »
Keep in mind what I’m trying to accomplish. I want the bars a couple inches higher and a couple inches back. Would these bars accomplish that?
Online Vagrant
« Reply #27 on: September 19, 2020, 08:39:03 PM »
Maybe u need to go look at one. & compare
Offline Ncdan
« Reply #28 on: September 20, 2020, 07:04:32 AM »
Now that I know what the bike is I’d say that should be the next step👍
Offline flower_king001
« Reply #29 on: September 20, 2020, 01:39:15 PM »
Rox Risers
Been using a set on my EV for several years...very adjustable~!
1971 BMW R90/5
1998 Moto Guzzi 1100 EV
2005 BMW 1200 RT
2007 BMW 1200 GS
2007 Moto Guzzi Breva 1100
