Author Topic: V7III Handling  (Read 6952 times)
Offline bikensail
V7III Handling
« on: October 03, 2020, 07:55:24 AM »
I just test rode a V7iii and had concerns with the handling.  I found it to be nimble at parking lot speed but it tended to "stand up" in corners at 40-50 mph. The tip in was normal but rather than a nice progressive increase in lean angle from there it would require a noticeable effort past that.
Immediately following that ride I took out a V85TT. It was totally different, being quicker to turn in and instilling confidence in its linear and neutral leaning at any speed.
2018 V7 Milano
2019 KTM 790 Adventure R
Re: V7III Handling
« Reply #1 on: October 03, 2020, 08:15:20 AM »
I have a 2015 V7 and have not noticed the phenomena you mentioned.
I do know from many posts on this forum that changing the V7III tires to Conti Road Attack III is transformative regarding handling, and I am looking forward to having them on my bike for the next set of tires.
Also, welcome to the forum.  Please take a moment to introduce yourself in the Introductions thread at the top of the forum.
Re: V7III Handling
« Reply #2 on: October 03, 2020, 08:29:37 AM »
Welcome to the forum.
I am really pleased with the predictable way my V7 handles but I'm sure if I was coming from a modern crotch rocket it would be quite scary.
I was reasonably happy with the tires fitted as new but i'm now running Avon Roadrunners.
Re: V7III Handling
« Reply #3 on: October 03, 2020, 08:43:25 AM »
I would also say that if you initial impressions of the V85 are more favorable that might be the most successful path.
If I had the leg length to easily mount and dismount a V85, I would probably have one.  I very much enjoyed my test ride.
Offline bikensail
Re: V7III Handling
« Reply #4 on: October 03, 2020, 09:34:00 AM »
I really liked the V85 but it is too close in function to my KTM which is a perfect on/offroad adventure tourer. I want what I feel the V7 is designed to be, and can modify it in many ways. However, a slow steering chassis geometry is not one of them if it is really the case.
« Last Edit: October 03, 2020, 09:35:01 AM by bikensail »
2018 V7 Milano
Offline HarveyMushman
    • Photo Galleries
Re: V7III Handling
« Reply #5 on: October 03, 2020, 10:05:10 AM »
Were the tires at correct pressures?  Your description doesn't match my experience.  The OE Pirelli's aren't very good, however.  A set of Conti radials will transform the steering and handling, and take the edge off the OE suspension's harshness.
The V85 is a completely different motorcycle so, yes, it behaves differently.
« Last Edit: October 03, 2020, 10:06:16 AM by HarveyMushman »
Tim
Offline usedtobefast
Re: V7III Handling
« Reply #6 on: October 03, 2020, 11:04:40 AM »
I agree, bet it was low tire pressure.  Could you do another test ride and check the pressure before the ride?
My v7iii does not handle like you described.
2017 V7 iii Racer
2017 Griso
2016 Stornello
2000 Red Quota
Offline Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
Re: V7III Handling
« Reply #7 on: October 03, 2020, 12:15:35 PM »
I know that the II and the III have different rakes. Keeping that in mind, I’ve allowed a couple people to test ride my V7 II, And every time, the response was that cornering was a bit difficult. I disagree, and think that it comes down to how one is accustomed to using their arms and body to control the bike. If the V7 III is at all like the II, it seems to require a little more hugging up and deliberate maneuvering, like I imagine a cruiser does. In other words, the “flickability” is there, but requires an adjustment in muscle memory.
« Last Edit: October 03, 2020, 10:30:12 PM by Dirk_S »
Offline Kev m
Re: V7III Handling
« Reply #8 on: October 03, 2020, 06:27:23 PM »
This doesn't compute to me either but there are a few possible reasons:
* Something wrong with the bike (like tire pressure or steering head bearing)
* Differences in tires.
* Differences in expectations.
* You're a dandy (just kidding, sorta). Weight distribution, your size, etc.
I mean I don't think our Ducati turns in any easier than our V7s, but I also think our V7's are downright nimble.
Hell I think my RK turns in with ease.
Could be perspective, or I'm not a dandy (still kidding, mostly).
« Last Edit: October 03, 2020, 06:28:27 PM by Kev m »
Offline blu guzz
  • Loves to ride
Re: V7III Handling
« Reply #9 on: October 03, 2020, 06:28:57 PM »
i own the v85.  last weekend at a rally, i test rode a v7 racer, the one with the ohlins rear shocks.  i really liked it, but it did not have quite the confidence inspiring handling as the v85.  i won't say it was bad because i was not familiar with it, but i don't think the standard tires are great.  i loved the engine smoothness though, especially at 5,000 rpm, almost ethereally smooth.
Blue Guzz
Offline subin
Re: V7III Handling
« Reply #10 on: October 03, 2020, 06:35:52 PM »
Not on mine (2019).
The V7 III (2700 miles) is nimble for me at that speed range. I find myself using my butt to steer the V7 most of the time between 40 and 60 mph.
The rear tire chicken-strip is less than 1/2" on both sides and I was riding comfortably.
When I picked up the V7 III, both tires were under inflated at around 25 psi, but I did not notice anything handling issue on my ride home (mostly freeway).
Some people suggested to raise the front tubes 10 ~ 20 mm from the tree to help turning in the corner, but I have not done that.
2019 V7 III Night Pack
2012 Ducati M796
Offline bikensail
Re: V7III Handling
« Reply #11 on: October 03, 2020, 07:45:55 PM »
Thanks everyone for your thorough replies. I am relieved to hear that this isn't an underlying handling trait. The bike was a 2020 demo and it could well have had under inflated tires.
I feel better in continuing to look for a V7 to complement my KTM 790 Adventure.
2018 V7 Milano
Offline alanp
Re: V7III Handling
« Reply #12 on: October 03, 2020, 09:34:14 PM »
Just another vote for "that doesn't sound right".  My V7II handles very nicely and is quite competent and predictable in its cornering.  And yes, the Conti Road Attack III's are completely transformative on these bikes.  I have never experienced such a dramatic transformation in a bike with tires alone, and if I had known how good they were, I would have had them fitted before taking delivery of they bike.  Sort of like getting a full top end suspension upgrade for the cost of a set of tires.
Niwot, Colorado
'16 V7II Stone - Black
Previous Guzzis
Offline greer
Re: V7III Handling
« Reply #13 on: October 04, 2020, 05:30:40 AM »
I found the steering head bearing tension way too tight on my used V7 II.  It wanted to stand up in corners, wagged at pavement seams, required constant correction at parking lot speed, and wove its way coasting to a slow stop.  Backing off the tension remedied all these things.  I can hardly wait to get rid of the Sport Demons.
Sarah
Re: V7III Handling
« Reply #14 on: October 04, 2020, 06:09:06 AM »
My Norge does the same as the tyres get near the end.
You need a lot of “down bar” at suburban speeds and it loses it’s neutrality. The higher speed handling does not suffer as badly though.
A new set of Pilot 5’s makes it feel brand new again..
Offline Vagrant
Re: V7III Handling
« Reply #15 on: October 04, 2020, 07:09:26 AM »
the stock tires are straight line only IMHO! It needs radials.
it takes 10 minutes on a III to drop the fork tubes. drop 12MM and you will only have to do it once. It's then a whole new bike.
Offline Roebling3
Re: V7III Handling
« Reply #16 on: October 04, 2020, 03:28:55 PM »
What Vagrant said!
My 2017 V7 III racer/poser handled badly out of the crate. The suggestion to pull the fork tubes up 12 - 15mm made the difference.
As noted herein: front end geometry is very different on the three series, along w/many other subtle improvements.
Depending how the 'factory' installed the wiring harness the clutch lever may be 'heavy' (tight radius cable bend), and the wire loom
will likely go betwixt the top & bottom steering head clamps; limiting the amount of change.
My bike came with Pirelli Demons.  I've used them for several years on 2 stroke race bikes, on the street. Good stuff, in my view.
They do wear faster.   R3~
Offline chuck peterson
Re: V7III Handling
« Reply #17 on: October 04, 2020, 06:38:42 PM »
Small changes to the rotation of the handlebar can have an effect on that
Experiment
Rolled forward/upwards
Rolled backwards/downwards
You are playing w arm length and posture
I recently moved mine forward and immediately found i tended to pull on the opposite bar while tipping into a curve
Lowered them and found it wanted a push on the bar forward in the direction of the turn and took less effort
Just the bar rotation made the difference
Some guzzi bars place the grips at 90 degrees to the fork
Other models place the grips parallel to the ground..one never knows the set up made w a demo
The brochure for the V700 has them rotated above parallel to the ground...quite a ways up
Small changes one a time and you can feel a difference
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
Bert Remington
Re: V7III Handling
« Reply #18 on: October 04, 2020, 06:45:47 PM »
CP -- great information.  Thanks.
Wildroamer
Re: V7III Handling
« Reply #19 on: October 04, 2020, 07:26:49 PM »
Experiment
Damn. Thanks for that excellent information. As I have been trying to hone my very rusty riding skills, I have been noticing how I tend to use both hands, one pulling the other pushing, and have been making a conscious effort to try to push only. I have already rotated my bar back closer to me a bit, but may try a little more following this post.
Offline bikensail
Re: V7III Handling
« Reply #20 on: October 25, 2020, 12:17:17 PM »
Well I liked what you guys had to say and bought a 2018 Milano. I am loving it. Thanks.
2018 V7 Milano
Offline voncrump
Re: V7III Handling
« Reply #21 on: October 25, 2020, 01:32:27 PM »
Sarah
My V711 had overtight steering head bearings from new.
When I mentioned it to the salesman he said “yeh our demo bike had tight bearings as well”
It made a huge difference when I adjusted them.
All of a sudden I had a light responsive bike instead of a vague feeling one.
Cheers, voncrump
1996 1100 sport
2016 V711
1988  Lario ( long gone )
1982 V50111 (long gone)
Offline aproud1
Re: V7III Handling
« Reply #22 on: October 25, 2020, 02:51:13 PM »
Congrats! I love mine.
Raising the front forks around 10 - 15 mm will do wonders for the front end feel and help steering. As well as setting up the suspension properly.
The Past: ‘76 KZ400S, ‘06 VN750 (pita), ‘18 V7III Milano, '20 V85TT McD, ‘21 W800,  ‘81 CB650C
Offline bikensail
Re: V7III Handling
« Reply #23 on: October 25, 2020, 03:44:31 PM »
I should have added that the main reason for the issue was the new tires. The bike I bought did the same thing until I ran it through the mountains and broke in the tires. It is fine now. I am going to try raising the forks as suggested also.
2018 V7 Milano
Wildroamer
Re: V7III Handling
« Reply #24 on: October 25, 2020, 05:11:17 PM »
That 1/2" I went with made a world of difference to the way mine handles.
Offline Siamese
Re: V7III Handling
« Reply #25 on: October 26, 2020, 10:04:06 AM »
Congrats to the OP for getting the Milano.  I have an '18 Special, and found the handling to be just fine.
When the original tires got thin, I replaced with the Conti Road Attach 3's, and as a previous responder mentioned, they noticeably improve the handling of the bike.  I've ridden since the 60's, but have never been an aggressive rider or particularly sensitive to handling issues, but immediately noticed improved handling with the 3's.  The bike always felt like it was on rails in a curve, but the new tires make it even more predictable in the curves.
Hope you enjoy your Milano!
Re: V7III Handling
« Reply #26 on: October 26, 2020, 11:27:00 AM »
When the tires are used up get Conti RA3's.  BIG improvement.
Wildroamer
Re: V7III Handling
« Reply #27 on: October 26, 2020, 01:44:47 PM »
As a fellow northeasterner, curious how long it took you to wear out those so-so Demons? Or maybe you were on something else prior to the Conti's?
Offline Chethro
Re: V7III Handling
« Reply #28 on: October 26, 2020, 01:51:11 PM »
My rear Demon was toast at 2500 miles the front lasted until 5200. At about 4500 miles the front started giving me some shake in fast bumpy curves. not terrible but it went away with a set of Conti RA3's.  :thumb: After 800 miles on the Contis,  I have to say I prefer them.
I never had a big problem with the Demons other than the head shake at the end of life on the front.
« Last Edit: October 26, 2020, 01:54:53 PM by Chethro »
2018 DR 650
2020 V85TT
2022 V7 850 Stone
Wildroamer
Re: V7III Handling
« Reply #29 on: October 26, 2020, 02:00:18 PM »
Thanks for that! I find them just a bit more squirrelly than I'd like, especially on colder and rougher roads.
