Author Topic: Phase 1 of the Stone tune done  (Read 1610 times)
Online Ncdan
« on: October 08, 2020, 08:19:14 AM »
With the help of one of the guys here, we hooked the Stone up to Guzzidiag to get the reading. The 02 sensor was -12 so we brought it back to 0.  After a 300 mile yesterday it seems to not have made much of a noticeable difference one way or another. I got 51 mpg on one tank of fuel and 53 on the other, the bike ran great. I did get a couple hiccups over the 300 miles, at low speeds in town and the weather was quite warm.
When I get home the next phase will be done, balancing the throttle bodies and check the TPS. The Twinmax meter came in and I look foreword to learning how to use it.
GeorgiaGuzzi
Re: Phase 1 of the Stone tune done
« Reply #1 on: October 08, 2020, 08:50:42 AM »
Great news!
« Reply #2 on: October 08, 2020, 09:40:12 AM »
The Twin Max is a good tool if you learn the right way to use it.. the sensitivity dial is the key.. you don't just hook up and read it.
« Reply #3 on: October 08, 2020, 10:58:44 AM »
Glad you got it back to 0.  If you want to see what it looks like in the real, get bike warmed up from a ride then put in new gapped plugs & let idle for 2+ min.. Pull plugs and inspect. It will be on cold start mode at initial start but that goes away, that's why let it idle 2+ min. Don't give it any throttle at start just the button.
Online Ncdan
« Reply #4 on: October 08, 2020, 11:40:16 AM »
Thanks Steve, I’ll get back with you when I get back off my trip at the Outer Banks👍
Online cliffrod
« Reply #5 on: October 08, 2020, 03:13:49 PM »
Sounds good, Dan.  Glad it's moving in the right direction.
Online Ncdan
« Reply #6 on: October 08, 2020, 04:24:22 PM »
Just got back to the room from a 150 mole excursion on the OBX. I think I do have a minor glitch as at low RPM I’m getting “ coughs” right frequently. I’m not sure if I got an issue that balancing the TB a d resetting the TPS is going to fix?
Bike still runs great at normal operating RPM and speeds snd the last tank in got 53mpg again.
Offline moto-uno
« Reply #7 on: October 08, 2020, 06:56:56 PM »
 ^  I gotta ask , what is a "150 mole excursion on the OBX" mean ?  Peter
Online TN Mark
« Reply #8 on: October 08, 2020, 07:37:52 PM »
With 50+mpg is it running too lean thereby causing the occasional hiccup?
Online Ncdan
« Reply #9 on: October 08, 2020, 08:09:43 PM »
Sorry Moto, I need to start proof trading my texts. I meant to say 150 mile ride(excursion) on #12(highway) on the NC outer banks.
« Last Edit: October 08, 2020, 08:11:39 PM by Ncdan »
