Author Topic: Breva 750 ECU  (Read 1980 times)
Offline Phil/TX
Breva 750 ECU
« on: October 22, 2020, 09:34:48 AM »
Who can re flash a Breva E.C.U. It has that surge between 2800and 3200 rpm on constant throttle.
"You will seldom regret what you have done, but you will always regret what you have not"
2024 V7 Stone Corsa (850)
2024 Triumph Speed 400
20 Guzzi V85TT Coast Guard (super chicken)
23 V100 S Mandello ( wing man)
Offline malik
Re: Breva 750 ECU
« Reply #1 on: October 22, 2020, 02:02:51 PM »
Sounds like a flat spot in the TPS to me. Been there. Had the miss (intermittent, but persistent) at constant throttle on the V7C for years, until I learned how to use Guzzidiag to identify it. You can also use a voltmeter on the TPS to check it. I replaced the TPS & not a problem since. A mate, however, got rid of the flat spot (on a Cafe Classic - same engine & ECU) by applying some lube into the TPS body. Worth a go. If you need a new TPS, they are cheaper from Harley, and secondhand ones from Euro car wreckers - there's a list of cars that use the same TPS in the Files Section on Moto-Guzzi-750@grouos.io.
Offline hzbloke
Re: Breva 750 ECU
« Reply #2 on: October 22, 2020, 04:22:48 PM »
I'm with Malik. I replaced the TPS on my Breva and the problem went away. The Harley one (part No. 27629-01A) is cheap.
There's a thread here: https://wildguzzi.com/forum/index.php?topic=101775.msg1609317#msg1609317
2019 Kawasaki Z900rs
2008 Breva 750
1986 BMW R65
Offline sign216
Re: Breva 750 ECU
« Reply #3 on: October 22, 2020, 07:33:02 PM »
The Breva has the old style ECU.  MyECU of Australia made replacement programmable ECUs for it.  I have one, and love it.  Although the company's website and forum are still up, I'm not sure they are in production, but I'd give them a look.
Joe
https://cajinnovations.com/yabb0/YaBB.p
https://www.myecu.biz/MyECU/index.htm
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
Offline pauldaytona
    • Paul's fast Guzzi Page
Re: Breva 750 ECU
« Reply #4 on: October 29, 2020, 04:28:47 PM »
Before you do anything, just get some windows laptop, and load Guzzidiag on it. Order a set of cables at Lonelec in the UK. There is a topic ( or more) what to do step by step.  First thing to read is the tps value with closed throttle.
Paul
Daytona 1225, Stelvio 1151
Offline sign216
Re: Breva 750 ECU
« Reply #5 on: October 30, 2020, 05:37:04 AM »
Is there a Linux capable version of Guzzidiag?  As Guzzi owners, we tend to be "outsiders."  I am a Linux user, and suspect many others are.
Joe
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
Offline malik
Re: Breva 750 ECU
« Reply #6 on: October 30, 2020, 02:42:06 PM »
Joe
Yes, mate. Linux versions of all the modules are on the Guzzidiag website. Beetle himself seems to prefer Linux, so it's the choice of champions.
Offline sign216
Re: Breva 750 ECU
« Reply #7 on: October 30, 2020, 04:56:35 PM »
Lol, I should have expected that from the unconventional Guzzi people.
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
