Author Topic: Tires for '98 EV ?  (Read 4118 times)
Offline kballowe
  • - Kevin the Great -
Tires for '98 EV ?
« on: November 01, 2020, 04:22:38 PM »
110/90-18 Front
140/80-17 Rear
The front selection is somewhat limited and the rear selection is very limited.
Suggestions ?
Re: Tires for '98 EV ?
« Reply #1 on: November 01, 2020, 04:28:25 PM »
I'm partial to Metzler 880.
That's all I've ever run on my EV.  The wear like iron and I find they handle well.  Many here disagree about the handling.  And they aren't particularly cheap for bias tires.
Offline Guzzidad
« Reply #2 on: November 01, 2020, 05:30:28 PM »
   Shinko. And put a 130 on the rear
Online n3303j
  • Ron Cichowski
« Reply #3 on: November 01, 2020, 06:19:11 PM »
Really happy with Michelin Pilot Activ on my '98 V11EV.
GUZZIDAD: Why the undersized tire recommendation for the rear?
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline kballowe
« Reply #4 on: November 01, 2020, 06:22:04 PM »
It's hard to find a matching set for this bike.
So far, I've found Pirelli Sport Demons and Metzler 888's
Add D404's, Shinko 230's, and a few others, if you can do with a 130/90 on the rear .vs 140/80.
« Reply #5 on: November 01, 2020, 06:32:18 PM »
 Go down one width on both ends , the handling will improve .
 Oh , Shinko .
Offline antmanbee
« Reply #6 on: November 01, 2020, 07:14:26 PM »
I agree with running a 100/90 on the front and drop the forks a bit. Run a 130/90 on the rear too. I also use Shinko 712's.
« Last Edit: November 01, 2020, 07:45:52 PM by antmanbee »
Offline Guzzidad
« Reply #7 on: November 01, 2020, 07:38:51 PM »
    A 140 on the rear clears the swing arm by just thousanths of an inch. As the tire wears, after thousands of miles, it's shape might widen just a bit. Drove me crazy trying to find the source of vibration my bike started having at slow speeds.
Offline Guzzidad
« Reply #8 on: November 01, 2020, 07:48:45 PM »
    Shinko TourMasters from Dennis Kirk is under $150 a set. I wouldn't put Shinko's on my Norge, but they work great on a California. Shinko used to be Yokohama, a well known brand.
Offline Madtownguzzi
« Reply #9 on: November 01, 2020, 07:53:36 PM »
I have been running Bridgestone Battlax BT45 Tires in the stock size for years with good luck.
Randy S.
98 V11 EV
05 HD Electra Glide Classic
Madison, WI
Offline pehayes
« Reply #10 on: November 01, 2020, 08:00:42 PM »
Me too, but the last I checked Bridgestone had dropped one of the stock sizes.  So, change or modification is forced.
« Reply #11 on: November 02, 2020, 12:04:30 AM »
I've heard nothing good about the 888.
Offline Bulldog9
« Reply #12 on: November 02, 2020, 12:59:23 AM »
I have an aging set of the Bridgestone BT-45s on my Convert that are decent and have good grip in wet and dry conditions. A set of Pirelli Route 66s on deck, will put them on in the Spring.
MGNOC#23231
Offline s1120
« Reply #13 on: November 02, 2020, 04:39:04 AM »
I belive the stock size rear was 130/90 before 02... but either way I went with the Shinko tourmasters on my 02 cali stone and love them. I kept the stock 110 front though.  Much nicer then the old lazertecs I took off!!
Paul B
Offline ejs
« Reply #14 on: November 02, 2020, 04:49:38 AM »
I run Shinko tubed 705 on my California EV 1999, Just for fun. Looks Cool.💣💣
California EV 1999
Offline kballowe
« Reply #15 on: November 02, 2020, 05:48:59 AM »
I've mounted a lot of the 880's and the newer 888's - but never actually ran a set on one of my bikes.  They are most excellent tires.
« Reply #16 on: November 02, 2020, 06:16:02 AM »
Shinko 712 are working well on the Cal Vin. Priced right and hook up nice.
Offline kballowe
« Reply #17 on: November 02, 2020, 06:19:27 AM »
It used to be that we were wary of buying cheap tires that were made in weird places, but I have a set of Michelin Commander II's here - made in Thailand - and have seen many name-brand tires made in Malaysia, Philippines, Vietnam, etc.   Shinko is (like someone else said) made in South Korea and is the old Yokohama brand.
Our '00 Jackal has Avon "Storm Rider" 110/90 F; 130/90 R.  The EV has 110/80 F Avon "Storm" and 140/70 R "Azaro".  These are all made in England.
So, I am leaning toward a set of those Shinko tires..... but, which one ?  712's ?  230's ?  I'd have to run a 100/90 .vs 110/90 front if choosing the 712's, as they don't offer that 18 in a 110 width.  Each offer the 130/90-17 rear.
« Last Edit: November 02, 2020, 07:29:22 AM by kballowe »
Offline bodine99
« Reply #18 on: November 02, 2020, 07:12:07 AM »
Triple 8's :thumb:
Offline Mike Crenshaw
« Reply #19 on: November 02, 2020, 10:11:46 PM »
I agree that stepping down one size width will tend to improve handling. Does this also have any effect when riding two up?
03 Moto Guzzi California EV
18 BMW R1200RT
75 BMW R90/6 Elwood
80 BMW R80/7
74 Yamaha TY250A
06 Suzuki DR650
68 Triumph TR25W
Offline flower_king001
« Reply #20 on: November 03, 2020, 03:52:02 AM »
110/90-18 Front
140/80-17 Rear
Suggestions ?
Shinko  Rear Tire 130/90-17
Shinko Front Tour Master Tire 110/90-18
I get around 6,000 miles out of these
Metzeler? Used to run them till this (check out photos of my actual rear tire)
https://wildguzzi.com/forum/index.php?topic=92730.0
1971 BMW R90/5
1998 Moto Guzzi 1100 EV
2005 BMW 1200 RT
2007 BMW 1200 GS
2007 Moto Guzzi Breva 1100
Offline Tim Henry
« Reply #21 on: November 03, 2020, 05:22:19 AM »
I got the 07 Calvin from antmanbee with a fresh set of shinko 705s back in April I've put 8k miles on it since and ill probably get another 2k from them before cross show only thing is they are noisy and can feel a little bit more vibration on some surfaces but would get another set. I used the same on my 07 Bonneville with sidecar when I was on st croix in the virgin islands because the roads were so bad and I had a steep driveway
Offline s1120
« Reply #22 on: November 03, 2020, 06:23:32 AM »
I used the 230 on my cali stone. Reviews seem to show they last a little longer then the 712, and they were only around 10 bucks more. I dont have enough miles on them to really rate how long they will last, but they ride and handle well.
Paul B
Offline kidsmoke
« Reply #23 on: November 03, 2020, 12:32:50 PM »
Kevin I go with the exact sizes you list in your original post on my '00 Jackal, and found Michelin Pilot Activ's no problem to source or run. Last bought a pair this spring.  Very happy with them.
'79 G5      (Gina)
'93 1000S (Monica)
'00 Jackal  (Claudia)
'09 GRiSO  (Perla)
Offline kballowe
« Reply #24 on: November 03, 2020, 12:36:16 PM »
Ha !  Add another choice to the list !
Thanks !
« Last Edit: November 03, 2020, 12:46:32 PM by kballowe »
« Reply #25 on: November 04, 2020, 04:34:33 PM »
Thanks !
Pilot Activ's wore like...marshmallows on the LMIII. Sticky but high priced and low mileage IMO. They were fun while they lasted!
Offline Lefty
« Reply #26 on: November 05, 2020, 05:18:14 PM »
I’m running Michelin Pilot Actives and they’re great tires.
1972 Husqvarna CR250
1973 Penton 250 Hare Scrambler
1995 KTM 620 Super Comp
1995 Honda Nighthawk
2001 Moto Guzzi California
