Author Topic: 73 Eldorado - port size to balance carbs  (Read 1570 times)
Offline cappisj1
« on: November 21, 2020, 08:27:17 PM »
I added a 73 Eldorado to my ride options. The intakes don’t have ports to balance the carbs. I have gauges that I used to balance my 75 T. What are my nipple options and best way to add them?
73 Eldorado
75 T Cafe
08 Norge
23 V85 Travel
Re: 73 Eldorado - port size to balance carbs
« Reply #2 on: November 23, 2020, 12:20:10 PM »
The thread is 6mm
If you get a couple of 6mm grease nipples and file the tip of the threaded end the spring and ball will pop out leaving you with a nice hose fitting.
You would also need screws to blank it off later, an "O" ring works as a seal.
Use rubber hose for the first few inches, plastic will get soft and fall off when the manifold gets warm
Having said all that I just use a drill bit to measure the slide opening on my 72 Eldo, I don't believe the balance is that critical.
« Last Edit: November 23, 2020, 12:24:36 PM by Kiwi_Roy »
