Author Topic: Tonti Steering Stems  (Read 1890 times)
Online Turin
« on: November 24, 2020, 10:53:39 PM »
Odd question. I have a rebuilt LeMans 1000 front end that I want to attach to a 70's T-3 steering head. the lemans 1000 steering stem is too long for that frame. Will a shortneck steering stem fit the lemans 1000 triple clamps ?
I'm not intersted in a gsxr or honda front end, trying to keep it guzzi.
1985 Sidlow Guzzi
Offline kfz
Re: Tonti Steering Stems
« Reply #1 on: November 25, 2020, 01:41:07 AM »
I think the stem is same diameter.  Compare the bearing sizes?
Why are you doing it.  if its for handlebars i have a 40mm SPIII top yoke for handlebars.
Kev
Online Turin
« Reply #2 on: November 25, 2020, 07:49:17 AM »
I have a rebuilt set of 40mm lemans 1000 forks and triple clamps that I want to use for my project. I cross referenced the bearings and that matches. What I'm worried about is the diameter of the base of the stem which will need to be pressed into the new lower clamp.
1985 Sidlow Guzzi
« Reply #3 on: November 25, 2020, 08:12:11 AM »
Unlikely that Guzzi would change that size for just one model. I'll bet the stem diameter is the same (at least) for all early Tonti frames if not all big twins.
Offline Groover
    • Scooteropolis
« Reply #4 on: November 25, 2020, 08:15:51 AM »
I also believe they are the same from past research on this, but I'd also like to know 100%. Hopefully someone will pitch in with the "ya, I've done it" response.
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
« Reply #5 on: November 25, 2020, 10:17:21 AM »
I swapped a stem out once before and had no issue with pressing the stem into a replacement lower clamp. Do you know the length of stem you need? I may have one in my stash
Jim
Online Turin
« Reply #6 on: November 25, 2020, 06:30:08 PM »
Jim, I need the eary tonti 170 mm long stem. That would be great if you have one.
1985 Sidlow Guzzi
Offline wirespokes
« Reply #7 on: November 25, 2020, 06:36:24 PM »
Rather than pressing the stem out, I'd rather heat the lower clamp to 250f and the stem will drop out.
« Reply #8 on: November 25, 2020, 06:38:07 PM »
I will see what I have and let you know.
Jim
Offline acguzzi
« Reply #9 on: November 27, 2020, 10:32:39 AM »
just to give you more confidence, I have done exactly the same thing with no issues.
Online Turin
« Reply #10 on: November 27, 2020, 05:30:48 PM »
Fantastic!
1985 Sidlow Guzzi
