Author Topic: Best time to change engine oil?  (Read 5817 times)
Online Perazzimx14
Re: Best time to change engine oil?
« Reply #30 on: December 15, 2020, 05:10:56 PM »
Yup. I can’t worry about acids AND zddp. Mayonnaise is your enemy in the cold. So if you start it during the winter, ride it till it comes up to temp.
Getting the oil to "operating temp" is not always doable. Ever ride a air cooled bike when the mercury dips into the teens and twenties? My DR650 with oil cooler totally blocked will only see oil temps into the 150/180 range. The boxers are worse.
This is one of the reasons the "additives package" is used. While I'd agree starting the bike and letting it idle thinking you are doing good is bad. Starting the bike to go on a ride is good even if the oil doesn't get up to ideal operating temp.
2017 Road Glide Special
2020 Kawasaki KLX300SM
Offline Ncdan
« Reply #31 on: December 15, 2020, 05:23:42 PM »
I am always cautious when giving opinions or asking advice when it comes to motor oil issues in our bikes. However I’ve got to ask this one.
Without sending off your oil to be Analyzed, which I would not do because I don’t let my bikes go that many miles between changes, I use this method as a basic guide when it comes to the condition of my oil.
When I pull out the dip stick I visually exam the oil. It it’s still transparent, my thoughts is that it’s not overly Contaminated and will still lubricant and cool the motor effectively. If the oil is black I figure it’s really dirty and questionable whether it is still capable of doing as good of a job oil is demanded and required to do. Am I way off base with this thinking?
Please be gentle 😉
Offline bad Chad
« Reply #32 on: December 15, 2020, 05:28:08 PM »
I think you are right on target.
Online Perazzimx14
« Reply #33 on: December 15, 2020, 06:25:59 PM »
Please be gentle 😉
The color of the oil is no indication of state of condition the additives package is in or its ability to lubricate. If dark oil was the matrix for change diesels would be a lot less desirable.
Offline Ncdan
« Reply #34 on: December 15, 2020, 06:55:19 PM »
Fare educated answer but to clarify my statement. I said “transparent” which is clear somewhat, that’s not color like black is. Does this discrepancy change anything?
Offline DaveJT
« Reply #35 on: December 15, 2020, 07:46:54 PM »
Well it does turn this into an “oil thread”. but other than that, no.
2000 Jackal
Offline Ncdan
« Reply #36 on: December 15, 2020, 08:07:08 PM »
Lol, I think it already had, thanks for the opinion 👍
« Last Edit: December 16, 2020, 07:57:38 AM by Ncdan »
Offline Gappy
  • StLouis MO
« Reply #37 on: December 16, 2020, 05:14:44 AM »
I change the oil when the bike is cold. All the crap is in the bottom of the pan and hs not been stirred up. Every forth one the pan comes off and I change the filter and wipe everything clean.
2003 Suzuki burgman an650
1994 Moto Guzzi California 1100
1992 BMW k75s
1983 Harley Davidson FLHT
1981 BMW r100rt
1981 Honda 650/4
Offline tazio
« Reply #38 on: December 16, 2020, 06:23:16 AM »
One of my bikes is an FLHXI Harley (nice enough bike with perfect fueling),
a few "Harley guys" told me to change oil when pressure gets too high (or was it too low?).
Don't know if there's something to that or not..
 I'll stick with 5k oil and filter, engine hot..
1967 Kawasaki 650 W2TT
1966 Triumph Bonneville
