Author Topic: VHB 29 - Single or Double Banjo  (Read 1955 times)
Offline cappisj1
« on: December 13, 2020, 09:26:11 PM »
73 Ambo 850. The current fuel line set up uses an “X” and single banjo’s on the VHS 29 carbs. Bike runs (ran) fine.
My 75’ 850T has VHS 30’s. When I rebuilt the T it had no “X”. It uses twin banjos on each carb with a line running from one carb to the next. More of a loop I would say. This bike runs fine also.
My question, is one setup better then the other. I have duel banjos that I can change too on the Ambo if I am convinced that one setup is better then the other.
Thanks,
73 Eldorado
75 T Cafe
08 Norge
23 V85 Travel
Re: VHB 29 - Single or Double Banjo
« Reply #1 on: December 13, 2020, 09:57:11 PM »
Thanks,
Other than one being a bit more simple than the other, there is no real difference. Use whichever "tickles your fancy".
Offline kfz
« Reply #2 on: December 14, 2020, 03:17:11 AM »
Not sure about Loopies but on Tonties the double banjo is easier to look after since the crossover line can be routed round the airbox.  The Old X crossover was prone to leaks and awkward to fit.
of course you can just run each tap to each carb, but it makes going onto reserve a bit of a pain.  doesnt stall or anything, but you need to do both taps.
Kev
Offline chuck peterson
« Reply #3 on: December 14, 2020, 06:30:19 AM »
A duel banjo on your left carb will let you go to reserve on both carbs w your left hand...don’t have to let go the throttle while you’re trying to keep it running
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
« Reply #4 on: December 14, 2020, 08:32:47 AM »
https://www.youtube.com/watch?v=b0eknUtEMWw
S'not a double banjo but it works.
« Last Edit: December 14, 2020, 08:34:38 AM by Sasquatch Jim »
Offline cappisj1
« Reply #5 on: December 14, 2020, 09:04:36 AM »
That video is amazing!   :cheesy:
I will get rid of the “X”. It is a pain to work with and I can see it as a possible source of trouble down the road.
Thanks again for the advice,
73 Eldorado
75 T Cafe
08 Norge
23 V85 Travel
Offline Markcarovilli
« Reply #6 on: December 14, 2020, 04:27:28 PM »
Surprised Chuck in Indy hasn’t chimed in on this, he had some personal experiences as I remember....
Mark
« Reply #7 on: December 14, 2020, 07:51:25 PM »
Mark
Yes.. yes I have.  :smiley: you couldn't pay me to use the X crossover.
Offline cappisj1
« Reply #8 on: December 14, 2020, 09:35:45 PM »
That picture makes me sick to my stomach.
I got everything back together from getting those bolts out of the generator mount to getting rid of the X in the fuel line. Cleaned so much crud and tidied up wires and connections and such. It started back up like a champ. But I either didn’t tighten the oil feed line or I should have replaced the crush washers.
73 Eldorado
75 T Cafe
08 Norge
23 V85 Travel
« Reply #9 on: December 15, 2020, 09:01:46 AM »
Sumting Wong.. :grin:
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
« Reply #10 on: December 15, 2020, 11:10:00 AM »
Looks like oil running down from about where the pressure switch is. Might check that.
Online Tom
« Reply #11 on: December 15, 2020, 05:16:08 PM »
Blow that up and make it a wall art piece.  :grin:
Online Tom
« Reply #12 on: December 15, 2020, 05:16:59 PM »
One way to prep the metal for paint.   :sad:   :grin:
« Reply #13 on: December 15, 2020, 05:46:17 PM »
And that would be a ‘73 Eldorado 850.
« Reply #14 on: December 15, 2020, 07:18:45 PM »
That would be a very nice V700.
« Reply #15 on: December 16, 2020, 03:47:41 AM »
OP’s bike.
