Author Topic: Dyna III. Aftermarket 5 Ohm Coil Options? And Resistance.  (Read 4135 times)
« on: January 04, 2021, 12:44:59 PM »
I'm considering running a Dyna III setup. I'm looking for aftermarket coil options. I know the Dyna 5 Ohm black coils would probably be best, but expensive.
What brand and model number 5 Ohm coils can be had at an auto parts store?
BTW: I did do a search for this info, but couldn't find what I'm looking for.
Thank you,
« Last Edit: January 11, 2021, 02:55:57 PM by Tom H »
Offline Testarossa
    • Skiing History
Re: Dyna III. Aftermarket 5 Ohm Coil Options?
« Reply #1 on: January 04, 2021, 01:00:58 PM »
Guzziology recommends 3-ohm (see section 6-33). Actual resistance is 3.3 ohms, and actual resistance of 5 ohm coils is about 4.5, so there's really not enough difference to worry about. Dyna coils are way overpriced.
I use this on both my Dyna III Guzzis: https://www.amazon.com/Bosch-00012-9220081083-Ignition-Coil/dp/B001CO4WA2 This may have been original equipment on the 850T and the coils on mine have lasted at least 50,000 miles. But the Haynes manual lists a Marelli 3.3 ohm coil as original equipment for early big twins.
« Last Edit: January 04, 2021, 01:22:54 PM by Testarossa »
Offline kirby1923
  • '81 CX100
« Reply #2 on: January 04, 2021, 01:37:12 PM »
FWIW
My CX has about 35K on dual head(plugs) w/3 ohm and they have outlasted the black box Dyna III ,( 25 years.)
« Last Edit: January 04, 2021, 02:27:21 PM by kirby1923 »
'81 CX100
« Reply #3 on: January 04, 2021, 03:19:52 PM »
I just run the original Marelli 3.3 ohm coils.
TOYS:
1985 Harley FLTC, 1985 K100RT
2001 Lees-ure Lite Camper,
1988 Mercedes 560SL
« Reply #4 on: January 04, 2021, 03:50:35 PM »
It looks like the 3 ohm coils will work from the replies so far. This is the info I had from doing a search here. But the Dyna 5 ohm blacks were also often mentioned and recommended if someone was having issues.
I did do a search at amazon. Found some Honda coils that are shaped like the Dyna's that might do the trick, cheap too. But again, it may be a get what you pay for item??
I'm really looking for something that's available at most auto parts stores with 5 ohm. But then again, a Bosch Blue or old VW generic can be had there.
As a side note. Is there a part number for the Tonti style small 3 ohm coils that auto parts stores carry??
Thank you,
« Reply #5 on: January 04, 2021, 04:59:41 PM »
73 Sport,
I did read that on their site. That's why I would prefer the 5 ohm coils. But at the same time, many have used the 3 ohm stock Guzzi coils with good results.
I'm looking at options in case I decide to stay with Dyna. Could just revert to dual points and be done with it?????
Thank you!
« Reply #6 on: January 04, 2021, 04:59:58 PM »
Thank you,
For street use, I recommend the black 5 ohm Dynas over the green 3 ohms due to the latters propensity to overheat easily and crack.
But, I think you'll be fine using any other brand of 3 ohm coil. I doubt any auto parts will have a coil as small as the originals.
I'd avoid any oil filled coil. I'd recommend using either the Bosch Blue Coil or the Pertronix Flame Thrower coil. The Pertronix can be found at Advance Auto, IIRC.
Bosch Blues are available on Amazon: https://www.amazon.com/Bosch-00012-9220081083-Ignition-Coil/dp/B001CO4WA2
Offline moto-uno
« Reply #7 on: January 04, 2021, 05:34:29 PM »
  The Accel 5 ohm coils have worked really well on my twin plugged Le Mans 2 for the last 3 decades .
  They have a lifetime guarantee ( which is good 'cuz as well as they work , every decade or so I've had
  to replace one . Keep your sales receipt :) ) . They do work well though .   Peter
Offline Testarossa
    • Skiing History
« Reply #8 on: January 05, 2021, 12:33:04 AM »
For a number of years I commuted on the 850T, with a lot of heavy traffic in hot weather. The 3.3 ohm Blue Bosch coils never failed.
« Reply #9 on: January 07, 2021, 12:32:03 AM »
With the advise, I'm still thinking about the coils.
Has anyone tried the Magna brand Dyna knock offs? Look the same and price is much lower.
« Reply #10 on: January 08, 2021, 03:24:11 PM »
I did find a standard style coil, about the same size as Bosch Blue or maybe a tad smaller. Emgo 24-71522. Not available in auto parts, but does have 5.5K Ohm.
I do have a question about secondary resistance. What would be better to have 10K, 14K or 17K Ohm?? IIRR Dyna black is 14Kohm.
Thanks again,
Offline wrbix
« Reply #11 on: January 08, 2021, 03:42:48 PM »
Don’t have my copy handy, but I recollect that Guzziology did recommend Pertronix Flame Thrower. Anyone confirm that?
« Last Edit: January 08, 2021, 03:45:10 PM by wrbix »
Bill in VA, sometimes FL
"Eschew aphorism"
LeMans IV - "Giulia"
Lario - "Giulietta"
V50III cafe'd - "Leggera"
‘77 Convert - “Sofia”
Classic Mini
‘60 Austin Healey Sprite
Caterham Super Seven Sprint
‘13 Audi TTRS
Grumman AA5B (sold)
Offline moto-uno
« Reply #12 on: January 08, 2021, 04:54:17 PM »
  ^^ The secondary with a higher resistance "should have" the potential for a greater spark energy . Peter
Re: Dyna III. Aftermarket 5 Ohm Coil Options? And Resistance.
« Reply #13 on: January 11, 2021, 03:08:32 PM »
The Should Have wording kinda made me wonder. So I spent about 3 hours searching what why low or high secondary resistance does.
After reading a lot on many sites. One set of sites I thought said that high resistance gave a bad spark. Another set said higher is better. The only thing I did find was that if your secondary generally test less than 10Kohms, it's going bad. But then again, many new coils have that or less?
The Dyna black S/B 14k
The Emgo S/B 10k
The Magna S/B 17k
The Bosch Blue S/B about 9k
I am going to run a pair of Bosh Blue for now. Still looking and still confused.
Rough Edge racing
« Reply #14 on: January 11, 2021, 04:07:07 PM »
  I have the Dyna type knockoffs on my Triumph 750...They do the job...
Offline baloo
« Reply #15 on: November 20, 2025, 08:48:30 PM »
Thank you,
Tom,
Did you ever try those cheap ohm Honda coils?
Thanks.
« Reply #16 on: November 21, 2025, 10:58:33 AM »
No I never did. I have a 1000cc roundfin engine in a Loop that had the dual point dist. with Dyna. The coil installation was a mess with the big Bosch coils., Could have cleaned it up a bit. But I ended up just going with the single point dist..
Offline wirespokes
« Reply #17 on: November 21, 2025, 04:53:21 PM »
I've wondered how to mount the larger Bosch coils in a Tonti. How'd you do it? Post some pix.
« Reply #18 on: November 21, 2025, 09:38:29 PM »
I don't think I have any pics of the Bosch Blues mounted. One was in stock Loop mounting and the other was on a home made bracket between the carbs and the battery. Very messy looking to me, but could have run it safely. I was only testing the set up to decide between the single and dual point dist..
Offline wirespokes
« Reply #19 on: November 22, 2025, 08:05:18 PM »
Never thought of mounting them separately in different places. Interesting idea.
Offline jkguzzi
    • JKnorth
« Reply #20 on: November 27, 2025, 07:43:18 AM »
This is where I mounted the Dyna coils on my Convert. There iis a 3/4" long 1/4-20 coupler behind the frame with a bolt through the front of the coil. They never moved for the 15 years I had the bike.
Offline PeteS
« Reply #21 on: November 27, 2025, 07:47:21 AM »
The posts on the Dyna coils are meant to be mounted to a heat sink. Thats what the holes in the posts are for.
Most don’t do that and thats the main reason they fail.
« Last Edit: November 27, 2025, 07:57:36 AM by PeteS »
« Reply #22 on: November 27, 2025, 11:36:43 AM »
Remember I was using Bosch Blue's for this on a Loop frame and it was mainly for testing. I remember now that the one between the carbs and battery I mounted to the tab on the frame backbone for the top of the stock air cleaner.
Had I decided to keep the dual pint dist., I maybe could have mounted the second Bosch coil near the steering head between the backbone and that U channel rail.
If I would have stayed with the dual point dist. that had been converted to the Dyna Ign., I was going to get the smaller Dyna coils and mount them better. I was mainly looking for a less expensive alternative set of coils.
Offline yackee
« Reply #23 on: December 17, 2025, 06:24:06 PM »
The dyna coils are very solid and mount very easily under the left-hand side cover, with just drilling a couple of holes. I have found that creating space under the tank by removing the stock coils, which are very large and fail very quickly if you leave the key on by accident, has some advantages. The cost of the dynas isn't that much.
