My wild a$$ guess......
Obviously, if you are truly changing the amount of fuel, then you would need to match it with a change in the air, the keep the mixture right. Just letting in more fuel without the air, doesn't do much.
And since we typically balance the vacuum, the amount of air should be close to the same.
What I suspect goes on is that the engine RPM has changed. At idle speed, the motor has slowed a bit before that first BOOM. And at the lower speed, the carb isn't going to supply as much fuel even though it is pulling all the air it needs. So you need to richen it a bit. The first BOOM increased the RPM, so the second BOOM has less troubling drawing fuel. It is unnoticed at higher RPM.
