Author Topic: Few questions about a cali 1100i?  (Read 21258 times)
Offline Tkelly
Re: Few questions about a cali 1100i?
« Reply #120 on: January 30, 2021, 04:21:19 PM »
On my 97 I would replace the tps like a set of points and no further problems.Buy a new one and set it right.I have one if you can’t get one locally.Send me your address if you want it.
« Reply #121 on: January 30, 2021, 08:26:36 PM »
Small update to this:
I soaked the TPS in isopropyl for a few days, I figured if excess fuel could trickle down and gunk it up then there's no need to drill it.
When I put it back on I managed to get it set to .400mv, and when back probed it still went up to a 4.8 peak.
Maybe that'll help, maybe not. I'm waiting on the new plug caps to arrive, so I'll give it a spin next week and see.
Cheers
That’s right in the ballpark!
« Reply #122 on: January 30, 2021, 08:41:58 PM »
Degrease the bike.
Offline lad
« Reply #123 on: January 31, 2021, 02:11:49 AM »
Degrease the bike.
how do you mean ? It's not very greasy. Is this about the injector manifold?
'96 1100i
Offline lad
« Reply #124 on: January 31, 2021, 02:13:09 AM »
I might do that if this doesn't yield any results, but there's no point replacing it if there's no need either. Thanks for the offer, I can pick up one easy enough on eBay, as I might revert to the PF09 when next I do replace it.
'96 1100i
Offline lad
« Reply #125 on: March 06, 2021, 03:39:13 AM »
Update, got a fuel filter, a Mahle, managed to replace it and that condensation pipe that was burst while I was at it, VERY tight in there now, the pipe wall was a little thicker than the stock.
I'm going to see if this makes a difference, next port-of-call is to clean the sensors, and failing that, the TPS
'96 1100i
Offline lad
« Reply #126 on: March 11, 2021, 10:26:31 AM »
eh....
Have i been duped? Why is the PF09 about 12 times bigger than the PFC3?
That's apparently the one for my frame number, but evidently they're not interchangeable? The thick plottens.
Pain in the ass. Guess i'm drilling and hoping
'96 1100i
« Reply #127 on: March 11, 2021, 02:40:04 PM »
Older model.
Offline Tkelly
« Reply #128 on: March 11, 2021, 02:53:12 PM »
The one in the photo looks nothing like the ones I got from Harley,made by Magni Marelli.My bike was a 97California.I will send it to you when I get home in April if you pay shipping.
Offline lad
« Reply #129 on: March 11, 2021, 03:34:39 PM »
happy to pay, is it the pf3c one? It's just confusing, the injector housing must be huge on the older models? even though technically mine is an older model, or someone just stuck that frame number badge onto it, or the parts list manual is for an entirely different bike...
'96 1100i
« Reply #130 on: March 11, 2021, 08:29:48 PM »
I'm not sure which thread to post this to. Per MG Cycle the PF3c fit's all FI models of the California series '98-'05. Here is a link to the page:
https://www.mgcycle.com/index.php?main_page=product_info&cPath=30&products_id=5333
I'm thinking the "correct" 9 with the direction the wires come out may have been updated to a 3 for the wires. Without being an electrical engineer and the test equipment to verify, I'm guessing the 9 and 3 have the same voltage ramp. HD has a TPS that fits But... from what I have read the voltage ramp is different. They are close enough to work, but IIRR they give a touch more fuel in the high end.
« Reply #131 on: March 11, 2021, 09:00:59 PM »
So you wanna know about tuning up the bike, here is what I go with:
https://archive.guzzitech.com/EVTuneup-Jeff_B.html
Another version with pictures:
https://bradthebikeboy.blogspot.com/2012/10/throttle-position-sensor-setting_21.html
Adjusting a TPS. I have read there are two ways. One is to mess with the idle screw on the LH TB and adjust the TPS to 150MV with the screw fully backed out. The other just says to adjust the idle screw to get 500-525MV.
If it were me and I'm changing the TPS. I would install the new TPS, Per The Instructions, back the idle screw out and adjust the TPS to get 150MV. Then I would adjust the idle screw to get the 500-525MV. Then follow the instructions to balance the TB's.
« Last Edit: March 12, 2021, 10:15:28 AM by Tom H »
Offline flower_king001
« Reply #132 on: March 12, 2021, 04:38:27 AM »
Tom,
 You are correct that the unit MG Cycle is selling fits a 1998 - 2005 Cali models but the bike in question here is not a 1998 - 2005 but an older bike that uses a different TPS
1971 BMW R90/5
1998 Moto Guzzi 1100 EV
2005 BMW 1200 RT
2007 BMW 1200 GS
2007 Moto Guzzi Breva 1100
Online JoeB
« Reply #133 on: March 12, 2021, 06:09:06 AM »
Adjusting a TPS. I have read there are two ways. One is to mess with the isle screw on the LH TB and adjust the TPS to 150MV with the screw fully backed out. The other just says to adjust the idle screw to get 500-525MV.
That 500 mv setting was for the smaller 1.5 ecu bikes.
For the larger P8 computer, at least in 1998, it was recommended to set at 378 +-15 mv after setting 150mv baseline.
Have seen several different ways to set up over the years. Most seemed to work well.
That fellow on guzzitech also did a write up on the harley tps for those interested: https://archive.guzzitech.com/HD-TPS-Jeff_B.html
I used the harley tps once on my 98ev. Noticed no perceivable difference riding. However I'm not a racer just a sedate tourer.
Prices on the Pf3c came down and went back to it.
« Last Edit: March 12, 2021, 07:58:27 AM by JoeB »
« Reply #134 on: March 12, 2021, 10:32:35 AM »
JoeB,
The voltage was something I was a bit confused about between the P8 and 15M. Thanks for clearing that up for me.
I am still wondering what the difference between the 9 and 3 TPS is other then the wire location? Also why you have to run a 9 with a P8?
Offline lad
« Reply #135 on: March 12, 2021, 01:18:24 PM »
I'm running an 8 with a 3... :shocked:
'96 1100i
« Reply #136 on: March 12, 2021, 05:05:11 PM »
Good luck....I'm out of trying to help with this!
1971 BMW R90/5
2005 BMW 1200 RT
2007 BMW 1200 GS
« Reply #137 on: March 12, 2021, 07:24:53 PM »
I found the difference in the other thread.
Offline lad
« Reply #138 on: March 13, 2021, 02:49:48 PM »
i’ll keep this going on a different thread as this was a multi-question, people of the future, here is the link
https://wildguzzi.com/forum/index.php?topic=109470.0
thanks for the help flower king
'96 1100i
