Hi, This is light years from being a new topic but just thought I would show my solution. Keep in mind that it is yet to be determined if this has weakened the swing arm significantly but I have a pretty good judgement on such things and feel it will be alright. If someone feels it will fail all I can say is time will tell. The slot in the swing arm could be top or bottom and could be strengthened by welding in a .100-125" thick slotted patch I would say 1/4-3/8" larger in all directions. The reinforcing patch would of course make it trickier to get snap ring pliers in but I'm sure it is doable.
I have had my LMIV engine/trans split a half dozen times for various reasons #1 would be clutch spline replacement. The first time or 2 the u-joint stayed with the swing arm but since it has always been loose and twice has had the famous 6 piece inner race even though it has never had roughness or vibration. I have tried LPS rapid steel,Loctite 271, and Locktite 680.I always thought the
high resolution photosnext disassembly would be a problem but it never has been as nothing has held. As well following the first inner race failure both u-joint and bearing were replaced.
I did this mod so I could assemble the bearing to the u-joint out of the swing arm. This time as always my u-joint feels perfect but needs a .003 shim to be a good fit. It was easy to do the .003" shim and 680 Locktite out of the swing arm. Doing the shim and locktite with the bearing in the swing arm would be hopeless.
My solution is a 3/8" wide slot 1.4" long as shown. I started at 5/16" but had to keep expanding it and experimenting with different snap ring pliers until I could reliably get the snap ring in and out.
MOST IMPORTANT!!! On assembly the snap ring must be in place before you put the bearing on
Then I made a installation tool much like you would use for normal u-joint installing Steel 4" long 2.685" O.D. 2.335 I.D.
This tool is now pushing on the relaxed snap ring and easily pushes the bearing perfectly flush where it is stopped by the expanded snap ring.
Now that the bearing is in that far and pretty well guaranteed straight you can easily work around the outer race with a skinny punch simply rotating the gap on the clip to access the race.
2ND. MOST IMPORTANT!!! if you drive the bearing in all the way now the snap ring is blocked by the knuckle of the u-joint and can't be compressed enough to get in.
Solution is only push the race in far enough to expose the start of the snap ring groove and now it is easy to compress the ring and start it into place. It should stay put when released and then finally tap around more with a punch now pushing on the snap ring and it will pop into the groove nicely.
Disassembly should be the reverse where you would get the ring up out of the groove and then let the bearing push it the rest of the way out. I am happy for now and didn't try disassembling it but not concerned of course you could also push the u-joint out of the bearing and take the bearing out normally.
I intend to cover the open slot with electrical tape or similar and back it up with a hose clamp. Should almost be unnoticeable on the bike.
