Author Topic: cleaning electrical connectors/connections  (Read 3540 times)
Offline SIR REAL ED
  • uh.... it's personal....
« on: January 27, 2021, 10:19:42 PM »
Any favorite techniques or chemicals or methods anyone would recommend?
Cleaning?
Corrosion prevention?
Thanks in advance!
2019 Beta EVO 250
Offline pehayes
Re: cleaning electrical connectors/connections
« Reply #1 on: January 27, 2021, 10:36:39 PM »
OK Wayne.   Here's a softball pitch for ya!!!!!
Offline Scout63
« Reply #2 on: January 28, 2021, 07:24:24 AM »
I like acetone for degreasing and ACF-50 for assembly. Dielectric grease for spark plug boots.
Ben Zehnder - Orleans, MA USA
« Reply #3 on: January 28, 2021, 07:44:51 AM »
Caig DeOxit. Accept no substitutes.. :smiley:
« Reply #4 on: January 28, 2021, 08:33:29 AM »
Nah, I gave up a couple years ago.
I now sit back and enjoy seeing people damage there equipment.
Offline n3303j
  • Ron Cichowski
« Reply #5 on: January 28, 2021, 08:47:59 AM »
Acetone may be okay on the Cape but here on the Mainland we prefer Naptha for degreasing. Acetone eats plastic, Naptha won't.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline Testarossa
    • Skiing History
« Reply #6 on: January 28, 2021, 10:13:58 AM »
Deoxit. And heat-shrink tube for waterproofing.
Offline n3303j
  • Ron Cichowski
« Reply #7 on: January 28, 2021, 10:24:02 AM »
....only if you use WATERPROOF heat shrink tubing. It has an adhesive liner that melts and seals to the the wire insulation to firm a seal as it is shrunk.
Regular heat shrink tubing does not form a waterproof barrier.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
« Reply #8 on: January 28, 2021, 10:33:37 AM »
That is good stuff. Sometimes I will put a thin layer of hot melt glue on a connection, then put regular heat shrink tubing over top of that, if I don't have the pre-made glue and heat shrink.
« Reply #9 on: January 28, 2021, 10:56:58 AM »
Vaseline for battery terminals prevents Lead Oxide mind you I've only been doing that for about 60 years. Vaseline is also good to lubricate sliding contacts.
In wet areas dip wires in something greasy before crimping to exclude Oxygen a dry joint will start to corrode within weeks, the grease keeps the copper bright.
« Last Edit: January 28, 2021, 10:59:34 AM by Kiwi_Roy »
« Reply #10 on: January 28, 2021, 11:23:59 AM »
DeOxit and ACF-50
Offline guzziart
« Reply #11 on: January 28, 2021, 02:54:59 PM »
FWIW, DeOxit worked great on my 40 year old Pioneer 1010 that developed scratchy potentiometers... no more scratchiness. :thumb:
« Reply #12 on: January 28, 2021, 04:10:36 PM »
I can't begin to tell you how many things I've "fixed" with DeOxit..  :smiley: The Kid fixed a $5000 relay in a helicopter one time..
Offline pehayes
« Reply #13 on: January 28, 2021, 06:46:42 PM »
I have two versions of DeOxit on the bench.  There is a "5" version which I think contains 5% of the very strong anti-corrosive chemicals.  Easy and cheap enough to spray on everything.  Then there is the "100" version which is 100% and thus VERY expensive.  I've used that to dissolve away all corrosion and salt from a badly leaking battery situation.  Worth every penny for saving important battery supply devices which may have been damaged.  Maybe Wayne can chime in with more knowledge about the various mixtures and what would be best for a single, general-purpose bench spray.
Offline SIR REAL ED
« Reply #14 on: January 28, 2021, 09:40:40 PM »
Excellent suggestions my Masters!
I humbly and gratefully study at your feet!   :grin:
2019 Beta EVO 250
