Author Topic: Moto Guzzi V7III multimedia platform pics  (Read 2642 times)
Offline guzzi771
« on: January 29, 2021, 04:39:07 PM »
Moto Guzzi multimedia platform
Re: Moto Guzzi V7III multimedia platform pics
« Reply #1 on: January 29, 2021, 05:27:52 PM »
Offline usedtobefast
« Reply #2 on: January 29, 2021, 06:00:44 PM »
Wow, you are the first person I've heard of that got it working!!
Does it really have info on how often traction control or ABS was activated?
And the lean angle stuff, does it have any historic info ... like after a ride you can see what happened?  Or is it all just instant display info only?
2017 V7 iii Racer
2017 Griso
2016 Stornello
2000 Red Quota
Offline guzzi771
« Reply #3 on: January 29, 2021, 06:46:12 PM »
  It has lots of useful stuff and yes you can see what you did on your ride. But to be honest I haven't used it that much and learned all the things it can do . Its really cool and nice to have tho .
Offline guzzi771
« Reply #4 on: January 30, 2021, 10:10:53 AM »
Not having any experience with the MMP, but thinking about the other thread regarding a method of getting a temp reading off the engine, does the MMP have a field that is able to display engine temp?
John Henry No engine temp display
Offline Bulldog9
« Reply #5 on: January 31, 2021, 09:01:23 AM »
John Henry
I've had mine running on the Stornello for almost 2 years. Is a decent app, though a bit wonky with connect and reconnect. You have to close and reopen the app every time you start the bike.
The 4 small fields on the left and one large on the right can be toggled and you can select from all the various options by tapping or swiping.
There is no engine temp info. Guzzi Diag lets you see the air intake and overall engine temp. It would be great if this app did too, but no mas. Would be nice to have an elevation and air temp reading too.
As to the question on data logging for the TC, I don't think so, but have never looked for that in the trip data, but the screen does weird things based on conditions. I think the 'trip' function gives miles, mpg, etc.
The little eagle turns red or green based on how 'economical' you are riding
The Screen will flash red at redline
The Screen color is different if you have the TC off
MGNOC#23231
Offline KonaDoc
« Reply #6 on: February 15, 2021, 08:11:30 PM »
I've been wondering about this multimedia application for a while for my V7III Stone. Primarily for a cross-country trip next year.
I'd love to hear from others who have experiences with this app.
Mahalo!
doc
2017 V7III Stone, 1972 Yamaha R5C
Offline bad Chad
« Reply #7 on: February 15, 2021, 08:48:52 PM »
Down load the app to your phone.  You can learn a fair bit just from the instructions and such, you don’t need the mgmp to do this.
1988 YX600 Radian
Offline KonaDoc
« Reply #8 on: February 16, 2021, 01:52:45 PM »
Good idea. I'll do that.
doc
Offline Bulldog9
« Reply #9 on: February 16, 2021, 07:57:37 PM »
Mahalo!
doc
Doc,
Is a decent app and gives you 5 fields to choose data from.  As said earlier, the only thing I find lacking is no engine temp info data. When the APP is open, it is only oriented one way which can be a pain depending on where your charging port is and how it is mounted.
Shoot me a PM here or in ADV if you want any specifics.
Hope you get to do that trip this year!
MGNOC#23231
Bert Remington
« Reply #10 on: February 16, 2021, 08:52:14 PM »
Master tuner chrisfer says engine temperature is available on the CANbus which is on the BlueDash/MGMP connector: https://wildguzzi.com/forum/index.php?topic=109113.msg1731640#msg1731640
Actually it's not clear this data is on the CANbus or K-line but probably CANbus.  I hope so because Louis97 accepted my challenge to connect a SpeedJut tachometer to the BlueDash connector and if doesn't work I'm out some $s.
Offline KonaDoc
« Reply #11 on: February 23, 2021, 04:39:17 PM »
Doc,
I downloaded the app to my iPad to get a feel for it. Seems to be a fairly decent amount of information available. Too bad about the limited orientation options. (ie none).
Do you feel like it was (is) a reasonable investment? Living in Kona, it would probably be of limited use around the island, but it should prove more useful on a multi-month trip. I'm wondering if the cost/rewards would be sufficient for a single trip. Of course, I suppose I could remove the hardware and sell it after my return.
Mahalo!
doc
Offline Bulldog9
« Reply #12 on: February 23, 2021, 04:52:00 PM »
Mahalo!
doc
Reasonable and Value is always subjective.  Do you like having a quick view of your current voltage, current gear, instant/average fuel mileage, a digital tach and speedo or any number of 10 options in one place for every ride? If so, you may like it and think it is worth it.
I do, though as I've mentioned before, I wish it had some way to display engine temp.  IMO, if you don't find that info valuable for normal riding, why would you for a trip?
MGNOC#23231
Offline KonaDoc
« Reply #13 on: February 26, 2021, 06:57:39 PM »
Thanks!
doc
