Author Topic: powder coating v7 gas tank?  (Read 1089 times)
Offline SpaceViking
« on: January 31, 2021, 05:36:13 PM »
I admit this is probably a dumb question, but here goes anyway...
I'm thinking of redoing the tank on my 2017 V7 III Stone with either powder coat or cerakote, but both of those processes involve a heat cure at around 400F degrees. I've done this with tanks in the past no problem, but to be honest this bike has way more technology in it than anything else I've owned, and I'm wondering if there's anything inside the tank that isn't obvious  (like the gas cap and fuel pump) that would have to be removed to avoid being damaged by the heat. The lack of any reference I could find to a tank liner or any other internal components suggest the answer is no, but I'm paranoid.
Offline malik
Re: powder coating v7 gas tank?
« Reply #1 on: January 31, 2021, 05:52:39 PM »
Ceramic coating must just be the go. Does both inside & out & is a thinner coat than powder. This would avoid getting rust inside the tank - like I recently found in my 2014 Special's tank. Check with the ceramic coating people (I'm going to). The threads under the tank cap surround and for the fuel pump would likely need protection. Other than the fuel pump and the tank cap surround, there doesn't seem to be anything else in there.
Offline SpaceViking
« Reply #2 on: February 01, 2021, 10:31:33 AM »
I didn't even think to do the cerakote inside and out. Good idea.
Offline malik
« Reply #3 on: February 01, 2021, 01:55:46 PM »
If they dip it in vats before the oven, there's no getting around it.
