Author Topic: Tube tire flat kit  (Read 8532 times)
Re: Tube tire flat kit
« Reply #30 on: February 17, 2021, 02:07:03 PM »
I strongly recommend you learn how to and practice fixing a flat. My V7 only had a side stand so I carried a Snap-Jack to enable lifting the wheel off the ground.
Yes on the practice, practice, practice.
More than once, I just laid the motorcycle on the side in the grass, and pulled the tire out. Might be a problem on a Norge, with the plastic, but most other models are easy.
Offline guzziart
« Reply #31 on: February 17, 2021, 04:46:44 PM »
I have used rope plugs on my own stuff on three different occasions and a few times to help others get back on the road.  The rope plugs worked fine to get me where I was going but then I replaced the tire as soon as possible.  I (personally) have little faith in their longevity.  I know of a fellow rider that plugged his tire several weeks prior to a ride to the Va. rally from NE Ohio, luckily he didn't have an accident as the tire deflated on I77s in Charleston, WVa.  He got the tire replaced at a local HD dealer.  I suspect he may not have properly installed the rope plug.  Or the rope plug failed from heat build up in the tire.  It was in the 90's that day, maybe the rope plug glue/sealant softened up and inflation pressure forced the plug out of the tire...idk.  I carry rope plugs on the bike and will use them as needed but I don't consider them as a lasting permanent repair.  Yeah, it's a pisser to toss out a baloney with plenty of meat on it.  And, noI ain't rich. :sad:
Offline egschade
« Reply #32 on: June 21, 2021, 01:30:29 PM »
Hey Rick,
When you put this type of product inside the tire, does it gum up the valve in the stem and cause problems adding/relieving pressure due to changes in the ambient temperature?
When I put it in my tubes I blew the stems clear w/ air before putting the valves back. Have checked pressure and added air a couple times w/o issue. Centrifugal force pushes it away from the stem.
« Last Edit: June 22, 2021, 08:20:46 AM by egschade »
The elder Eric in NJ
Past Guzzis:
2016 V7 Stornello #394
2018 V7 III Carbon Dark
1985 LeMans 1000
2020 V85TT Adventure
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
« Reply #33 on: June 21, 2021, 03:50:46 PM »
For rope plugs impossible to beat Nealy plugs.
https://www.nealeytirerepairkit.com/
I'll never have tubes ever again.  It's really the only automatic disqualifier for me-and no, this does not assist the OP!  FWIW, if it was my bike I'd swap wheels (which I did on my Jackal) or remove and seal.
« Last Edit: June 21, 2021, 03:54:03 PM by kingoffleece »
Offline ozarquebus
  • Grand Canyon Pack Rat
  • Riding since 1979
« Reply #34 on: June 21, 2021, 09:44:25 PM »
Hot Patch Kit was the best. Gone since, when? 1960?
Watching my dad fix the old skins on the '56 Plymouth was literally very flashy.
« Last Edit: June 21, 2021, 09:57:21 PM by ozarquebus »
 Convert Hangar Queen
