Author Topic: V85 throttle remedy.  (Read 9989 times)
Re: V85 throttle remedy.
« Reply #30 on: May 26, 2021, 11:48:10 PM »
Ok...perfect...gracias maestro.    Did you ever do any modifications besides the grips for the Norge?
Cheers.
Pertaining to the throttle pull ?
Online PJPR01
« Reply #31 on: May 26, 2021, 11:59:43 PM »
Yes...correct...jus t pertaining to the throttle pull.  Thanks!
Paul R
2015 Red/Black Griso
2008 Silver Norge
2002 V11 Scura
« Reply #32 on: May 27, 2021, 01:28:04 AM »
Yes...correct...just pertaining to the throttle pull.  Thanks!
I’ve done nothing to the throttle action, other than the bigger grips.
Online Wayne Orwig
« Reply #33 on: May 27, 2021, 08:04:23 AM »
I'm going back into mine. It will be pretty painless now with those screws out.
When I removed that second security screw, the cover came loose and the spring uncoiled before I noticed how it was attached. I THOUGHT I had reattached it with about a turn removed.  But no, I apparently just put it back like it was. A long ride yesterday has my wrist in pain again.
There is no reason for that much spring pressure on an electronic system. Obviously some worthless lawyer pulled that off.
Online Wayne Orwig
« Reply #34 on: May 27, 2021, 09:56:19 AM »
Plan B and plan C
For plan B:
When I first disassemble the throttle, I lost the original spring position. I THOUGHT I had returned it to a position with less force, but no, I think I put it back to the original position.
So I just disassembled it again (easy now) and relocated the spring from what I will call 1/2 turn, to resting on the aluminum clamp at maybe 1/4 turn. Wow. much better.
For plan C:
For my first pass, I had given the spring and such metal bits a tiny shot of ACF50 to prevent corrosion. After putting it back together I noticed that the throttle would 'tweak' a little when I would go over large potholes and such. Turns out some ACF50 got on the handlebar and made the throttle too slick. So, while thinking about that, I compared the V85 to my EV, which I have over 130,000 miles on and no real throttle complaint. I don't have a device to measure it, but I'll bet the EV needs as much or more force to twist the throttle. But the EV has enough drag in the system, that there is little force needed to HOLD the throttle. So for plan C, I am going to try an o-ring or such on the throttle just to see if the drag is maybe all that is needed in the first place. Of course I have it so light now that any drag on it would be bad.  :grin:
« Reply #35 on: May 27, 2021, 10:22:07 AM »
Yep, 90 deg of pre load is what I have.
Mentioned in reply #19.
Online PJPR01
« Reply #36 on: May 27, 2021, 10:33:19 AM »
Ok...thanks Peter!
Paul R
2008 Silver Norge
2002 V11 Scura
« Reply #37 on: May 27, 2021, 10:35:35 AM »
Online Wayne Orwig
« Reply #38 on: May 27, 2021, 02:47:17 PM »
For some reason I was thinking that the initial preload was 1 1/2 turns. So from there, I thought my 1/2 turn was going to be great. No, it turns out that 1/2 must be stock.  :boozing:
« Last Edit: May 28, 2021, 08:14:16 AM by Wayne Orwig »
Offline egschade
  • Eric - MGNOC NJ Rep - mgnocnj.forumotion.com
« Reply #39 on: May 28, 2021, 06:00:56 AM »
I like the Biltwell Renegade grips with their larger middle diameter. On my V85TT they do make the pull feel lighter w/o having to do the spring surgery. I'll ride with them, a Crampbuster and the cruise control for a while. Will consider the spring unwind after the season is over.
The elder Eric in NJ
2024 Triumph 400X Scrambler
1971 Honda SL350
Past Guzzis:
2018 V7 III Carbon Dark
1985 LeMans 1000
2020 V85TT Adventure
V65 SP
V7 III Stone
V50
Griso 1200SE Tenni
Breva 1100
EV Touring
« Reply #40 on: May 28, 2021, 06:56:27 AM »
They look very nice.
Offline Vagrant
« Reply #41 on: May 28, 2021, 07:55:44 AM »
If using the cramp buster on a V85 you need the name brand. I had 2 sets from China and they just slip. I put sand paper on the back side and it helped a bit.
Online Trialsman
« Reply #42 on: May 28, 2021, 09:24:38 AM »
I have used the cramp buster type device on my bikes and they really help.  To keep them from slipping I usually dremmel several cross grooves on the inside.  Leave the burrs for better grip.
2010 FE570 Husaberg
2019 Alta Redshift EXR
2021 Moto Guzzi V85TT Centenario
2024 Stelvio V100
2025 Arctic Leopard Ex-800
Offline egschade
« Reply #43 on: May 29, 2021, 09:49:01 AM »
Here's a picture of my setup...
1971 Honda SL350
Past Guzzis:
1985 LeMans 1000
V65 SP
V7 III Stone
V50
Griso 1200SE Tenni
Breva 1100
EV Touring
« Reply #44 on: October 07, 2021, 07:00:52 AM »
If anyone wants to try my lightened spare, they can keep it and post me back their std. one for the price of a forum donation.
« Reply #45 on: May 04, 2022, 06:26:20 AM »
Bumped for Tusayan.
Offline Tusayan
« Reply #46 on: May 04, 2022, 09:22:51 AM »
Thanks much
« Reply #47 on: May 05, 2022, 04:52:39 PM »
No…???
Offline Vagrant
« Reply #48 on: May 06, 2022, 07:45:32 AM »
Huzo's fix works great.
« Reply #49 on: May 06, 2022, 09:18:24 AM »
Once you get over the shock of how easy it is, you’d never go back.
Did you remove one full turn, so as to halve the load ?
Offline Vagrant
« Reply #50 on: May 06, 2022, 09:21:43 AM »
As I recall, I removed at least that. Anyway, very nice to use now.
« Reply #51 on: May 06, 2022, 09:34:59 AM »
I’ve always been partial to a nice gentle pull… :wink:
Online Trialsman
« Reply #52 on: May 07, 2022, 05:48:57 PM »
I have done it on two now and they are so much better.
2010 FE570 Husaberg
2024 Stelvio V100
« Reply #53 on: May 07, 2022, 06:12:20 PM »
I have heard the (partially justifiable) criticism, that it’s harder to hold the grip at a steady setting over bumps.
This is not entirely untrue but it can be learned.
 The only argument that could  be made, is that the heavier throttle necessitates the “locking” of your wrist to a larger degree, but that contributes to fatigue. I do not see why the grip needs such a heavy pull when it is not having to overcome any throttle springs or pre loaded quadrants.
An addition.
I don’t wholeheartedly agree that a heavy throttle is easier to hold still, since no matter how heavy the pull is, you still are balancing the wrist force against the spring for a net zero torque.
It’s the bouncing of the mass of your right arm over bumps or undulations that feed through to the ‘grip.
You just need to develop the required finesse.
« Reply #54 on: August 15, 2023, 01:30:21 AM »
This is virtually no different to BuckyMoto’s thread.
But if you can take something from it, you’re welcome. It’s fairly old news.
« Last Edit: August 15, 2023, 05:52:10 PM by Huzo »
Online Wayne Orwig
« Reply #55 on: August 15, 2023, 08:10:25 AM »
Simple fix.
In addition to unloading the spring, slip a large rubber oring over the end of the throttle. The added friction eliminates the 'floating' throttle feel.
