Author Topic: Start of a new project, "1200 Ambassador".  (Read 9869 times)
Re: Start of a new project, "1200 Ambassador".
« Reply #60 on: March 29, 2021, 03:40:00 PM »
Got it.
I thought the only mount was on the timing cover. I didn't see the 2 on the block.
Thank you,
« Reply #61 on: March 29, 2021, 03:47:16 PM »
Got it.
Thank you,
Although Stephen's are only bolted into the timing cover and that seems to work well enough, I'd feel a lot better having the block mounting points connected too.
Offline leroy_can
« Reply #62 on: March 29, 2021, 05:21:01 PM »
    Absolutely agree, tie into every mounting point available. Glad the mount worked for you. Apparently mail can still move pretty fast when it wants to.
1973 XLCH cafe Shovester #1
1973 XLCH cafe Shovester #2
1971 Homemade cafe '08 XB12S motor 71 CH frame
2002 Buell M2 Cyclone
1987 LMIV SE 1400 conversion in progress
Offline lucky phil
« Reply #63 on: March 29, 2021, 07:25:33 PM »
Well a Spine frame uses the engine as a stressed member and is happy enough with the front cover mounting points only. I'd just use whichever made the easiest and most elegant front mounts with adequate strength. Lets be honest it doesn't take "engineering" to just keep adding metal until there's no further points available. Elegant solutions "make" a conversion like this not battleship design.
Ciao
« Last Edit: March 29, 2021, 07:27:17 PM by lucky phil »
« Reply #64 on: March 29, 2021, 09:32:48 PM »
Good point. Thanks for your input.
« Reply #65 on: March 30, 2021, 10:23:08 AM »
Bought an 850-T rear wheel from Joe Walano. Thought a cush drive would be a good idea.
I'll be stripping it down and relacing with a Boranni rim.
« Reply #66 on: March 31, 2021, 08:35:00 PM »
Bought a used, low miles Norge flywheel and clutch assembly on ebay and it arrived yesterday. 7 lbs. 12.2 oz. for the flywheel and ring gear, compared to 13 lbs. for just the original Ambo flywheel.
Clutch plates measure in spec. and have perfect splines. Came with the springs, clutch pushrod thrust piece and hardware.
« Reply #67 on: February 09, 2022, 11:30:50 AM »
Hey Charlie, any updates on this beast?
« Reply #68 on: February 09, 2022, 12:42:49 PM »
Yes... on Facebook.
« Reply #69 on: February 09, 2022, 12:58:07 PM »
I'll have to see if I can find it thru my wife's account (i'm not on there)... would that be your biz page, or on one of the Facebook Guzzi groups?
« Reply #70 on: February 09, 2022, 03:50:32 PM »
On my business page.
https://www.facebook.com/media/set/?set=a.3562813957174043&type=3
Engine is mounted into the frame, frame repairs and reinforcement done.
Been trying different air box ideas, finally settled on something like this ("CAD") rendering. May go a bit taller for more volume. Yes, that the filter enclosure from a '70s Tonti-frame. It fits the space and clears whats in the way.
I'm running out of room to put things, so the air box may also be where the coils mount.
« Reply #71 on: February 10, 2022, 07:03:29 AM »
Thanks Charlie, cool beans.
Did the customer decide to forgo the carbs and run it with the stock injection?
« Reply #72 on: February 10, 2022, 08:46:20 AM »
No, that was my decision. The carbs would have required massive trimming of the battery covers. Plus, I think it will just be more "user friendly" with injection.
« Reply #73 on: February 10, 2022, 08:59:03 AM »
Awesome, I agree!
