Author Topic: Odd engine  (Read 1760 times)
Odd engine
« on: March 08, 2021, 06:31:56 PM »
This is a video of an engine I’ve not seen before. https://youtu.be/4Fkh-MmqOmc
Has anyone seen one in operation?
Re: Odd engine
« Reply #1 on: March 08, 2021, 07:10:56 PM »
My guess would be that is one cylinder in a bank for maritime application.  But just a WAG.
1970 Ambassador
2021 V7-850 Centenario
Offline lucky phil
Re: Odd engine
« Reply #2 on: March 08, 2021, 07:35:24 PM »
Nope, not seen this. Eight stroke engine then? Eight strokes/crank revolution. I'd like to know what the advantages and disadvantages are.
Ciao
Offline leroy_can
Re: Odd engine
« Reply #3 on: March 08, 2021, 07:45:58 PM »
  Something rings a bell about a very expensive Ducati single 20 or so years back but I could be way off
1973 XLCH cafe Shovester #1
1973 XLCH cafe Shovester #2
1971 Homemade cafe '08 XB12S motor 71 CH frame
2002 Buell M2 Cyclone
1987 LMIV SE 1400 conversion in progress
Offline kballowe
  • - Kevin the Great -
Re: Odd engine
« Reply #4 on: March 08, 2021, 07:56:38 PM »
Atkinson engine design.  The Toyota Prius (for one) uses an engine of this design.
Offline leroy_can
Re: Odd engine
« Reply #5 on: March 08, 2021, 08:12:18 PM »
 Here is what I had seen that triggered a memory. 1993 Ducati Supermono
  Not the same thing but you can see how I made the connection
Re: Odd engine
« Reply #6 on: March 08, 2021, 08:20:13 PM »
10500 RPM , that must’ve sounded incredible. Good find!
Offline lucky phil
Re: Odd engine
« Reply #7 on: March 08, 2021, 08:29:49 PM »
The best part is you can easily make one yourself if you feel the need. All you need is a twin engine and a bolt on section for the balance beam and the balance beam itself. Pretty easy and sorts the major primary imbalance.
Ciao
Re: Odd engine
« Reply #8 on: March 08, 2021, 11:43:04 PM »
Atkinson Cycle.  Variable stroke, the power and exhaust strokes are longer than intake and compression due the angle on the jack shaft (or whatchacallit). The cam is run on the mainshaft.
Offline jcctx
Re: Odd engine
« Reply #9 on: March 09, 2021, 11:12:53 AM »
Can't say about the Prius; but the "Atkinson " V6 in my Tacoma is an emulation of the mechanical one (as above) by using variable cam timing. Seems to work as I get 22+ mpg overall and has since new.
Offline Guzzistaracing
  • Norwegian with a love for all Italian
Re: Odd engine
« Reply #10 on: March 13, 2021, 01:43:18 AM »
If I look at the picture is it so that this system was used on the albatross racer from Guzzi also?
Ex.85�suzuki katana
 85`Le Mans 1000
`?? 1100 sport
`51 Ariel KH500
`07 Griso 850, black
`71 Nuovo Falcone civile
`78 BMW R100RS
`98 Centauro
`07 Norge
Current:
`99 Quota
`84 V65
Offline lucky phil
Re: Odd engine
« Reply #11 on: March 13, 2021, 05:11:58 PM »
No the Albatross had no imbalance compensation. No Guzzi single did.
Ciao
« Last Edit: March 13, 2021, 05:23:10 PM by lucky phil »
