Author Topic: Handle Bar Risers for 2006 Breva  (Read 1168 times)
Offline dragonstale74
« on: March 25, 2021, 07:25:50 PM »
Just purchased  my first Moto Guzzi a 2006 Breva 1100.  I am looking for a source to purchase a pair of bar risers for my bike.
Any one know of a source?
Dragonstale74
'06 Breva
'18 Goldwing Tour
'21 CSC TT250
Re: Handle Bar Risers for 2006 Breva
« Reply #1 on: March 26, 2021, 08:19:58 AM »
these are going to be tough to source, they didnt sell a lot of them to begin with, and aftermarket on these has been thin even when new. 14 years later, who knows. You might widen your search terms to 'Norge' instead of 'Breva' for a little better luck.
I know some folks have used sockets as risers with longer bolts. IIRC the top of the upper clamp is flat, you may be able to have some fabricated from thick aluminum plate, or do so yourself with a drill press and angle grinder.
Offline tris
« Reply #2 on: March 26, 2021, 08:49:39 AM »
Hi
I have for sale from my old 2005 Breva 1100
a) set of risers from a 1200 sport. they fit and allow you a choice of tubular bars
b) set of helibars which brings things up and back
If you're in the UK we should be able to sort something out, if else where, possible but a bit more tricky
PM me if you're interested and I can sort some pictures out
Tris
1993 TW125 "POS" - Resting
Offline ChrisG
« Reply #3 on: March 26, 2021, 10:20:04 AM »
To install he Helibar risers you may need a new brake line and extensions to the switch gear wires.  I had Spiegler make a longer brake line, but when I found I needed to lengthen the wires on the left side I said screw it.  My 06 Breva is gone now (with the uninstalled risers and brake line.)
Really though, give it a chance to get used to it as is.  Once I got some miles on it the stock height seemed fine.  Wait before you leap.
Current: 2022 V7 Stone 850
Gone: 96 California 1100i, 2008 Breva 750, 06 Breva 1100, 2007 Sportster,1971 BMW 75/5, 1969 Triumph Trophy
Forgotten: A couple Hondas, a Yamamaha, ??
Offline tris
« Reply #4 on: March 26, 2021, 10:32:48 AM »
My non ABS B11 need extended brake lines
I believe that the ABS bikes were OK
« Reply #5 on: March 26, 2021, 06:41:28 PM »
Thanks for everyone's input.  I will give it a go for a while to see if I get used to the riding position.
Dragonstale74
'06 Breva
'18 Goldwing Tour
'21 CSC TT250
