Author Topic: Cheap V85TT inner fender  (Read 3056 times)
Offline egschade
« on: April 10, 2021, 07:42:51 PM »
Lots of folks have noted that the high front fender on the V85TT offers little to no protection from road spray. My first ride on a wet dirt road totally covered the engine in mud. I considered the Caponord fender and Pyramid Plastics deflector but decided to do my own thing.
I bought this China rear fender skirt on eBay https://www.ebay.com/itm/Universal-Motorcycle-Rear-Fender-Wheel-Splash-Guard-Cover-Motorbike-Mudguard-ATV/143679868602 for $23.
Used the U-brackets to make 4 short tabs I bent to 100 degrees then fitted to the caliper bolts. The material is about 2mm so I don't think it will affect bolt retention. Just to be sure I used blue thread lock and torqued them to spec. Things are a little clunky as I only have hand tools - a drill press and grinder would have made for a better result but you don't really see things.
At first I had the brackets pointing up but that was too much of a gap and the fender hit the skid plate. Reversing them to point down made for a much better fit. The end result looks decent enough and is very effective at keeping things cleaner.
« Last Edit: April 10, 2021, 08:49:38 PM by egschade »
The elder Eric in NJ
2016 V7 Stornello #394
Past Guzzis:
2018 V7 III Carbon Dark
1985 LeMans 1000
2020 V85TT Adventure
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
Offline hauto
Re: Cheap V85TT inner fender
« Reply #1 on: April 10, 2021, 07:53:26 PM »
For 23 bucks looks interesting
« Reply #2 on: April 10, 2021, 09:21:07 PM »
That’s pretty darn good.
Although the look is an acquired taste, that is more than overcome by the indisputably good protection it affords.
Offline egschade
« Reply #3 on: April 10, 2021, 09:31:47 PM »
Yeah, not the prettiest thing but I was looking for function over form at this point. Would rather protect the bike on the dirt/gravel roads I intend to frequent more with this style bike.
Past Guzzis:
1985 LeMans 1000
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
Offline Vagrant
« Reply #4 on: May 08, 2021, 04:49:50 PM »
Within a day or so of seeing this, I ordered one. I'm sick and tired of cleaning off road tar and believe me the paint from the double yellow lines doesn't come off. It can't hurt as a flat tire deterrent either. It got here yesterday. not sure of exactly how he did the brackets but after trying to figure out a way to make the ones that came with it work I started cutting. Basically I
 snipped off the sides and drilled out the end hole so the bolt for the calipers would fit then opened the end so they slide over. making a 90 degree or so bend at the end and there you go. Nice and sturdy.
« Reply #5 on: May 08, 2021, 05:01:08 PM »
If I was taking my V85 anywhere serious, I’d copy that idea and bugger the looks for the trip.
Very good work IMO... :bow: :thumb:
« Last Edit: May 08, 2021, 05:01:38 PM by Huzo »
Online Matteo
« Reply #6 on: May 08, 2021, 06:45:00 PM »
Better than $100 plus shipping for the British version. Plus the gap is adjustable.  :thumb:
Offline egschade
« Reply #7 on: May 08, 2021, 09:41:43 PM »
Nicely done Vagrant. I basically did the same thing - used a section of the provided mounting bracket to fab 4 tabs and enlarged the one end to fit the caliper bolts. I have the brackets facing down so the fender sits closer to the tire. Too much of a gap and it will hit the front of the skid plate.
UPDATE: here's a a close up of the brackets I made.
« Last Edit: May 09, 2021, 09:24:24 AM by egschade »
Past Guzzis:
1985 LeMans 1000
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
