Author Topic: 2021 V9 Updates...  (Read 1801 times)
Offline SLDMRossi
2021 V9 Updates...
« on: April 15, 2021, 02:15:37 PM »
Offline Zenermaniac
Re: 2021 V9 Updates...
« Reply #1 on: April 16, 2021, 03:57:40 PM »
Says the frame is beefed up in the neck area. I would have thought the frame was strong enough - my ‘17 is rated for maximum rider, passenger and luggage weight of over 900 pounds. That’s twice as much as many bikes I’ve had in the past.
Offline Alfetta
« Reply #2 on: April 16, 2021, 04:02:59 PM »
As Moto Guzzi targets a younger generation all coming from supercross, they felt it a necessary move.
Look for the Guzzi embossed cross bar pad soon to be released.
Offline egschade
« Reply #3 on: April 17, 2021, 04:09:31 AM »
Frame flex and action is different than load capacity. The initial reviews I've seen indicate that the bike is more planted / stable at higher speeds with the reinforced head area.  I did notice a little high speed weave on my V7 III but wrote it off to as being on a lighter weight, naked bike.
The elder Eric in NJ
2016 V7 Stornello #394
Past Guzzis:
2018 V7 III Carbon Dark
1985 LeMans 1000
2020 V85TT Adventure
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
Online blu guzz
  • Loves to ride
« Reply #4 on: April 17, 2021, 07:37:08 AM »
also, with the added hp, you have to assume it can reach higher speeds so stability becomes more critical.  not that higher speeds are advisable, but if it can be done, they have to make sure it is safe.
Blue Guzz
