Author Topic: Loop Plugs  (Read 5565 times)
Loop Plugs
« on: April 15, 2021, 10:01:23 PM »
Greg Bender recommends NGK BP6ES plugs, he doesn't favour the BP7ES NGK suggest.
I went to Crappy Tire and couldn't find either of the so I picked up a pair of BP5ES that they did have.
Apparently this is a hotter plug than the BP6ES
Would it do any harm to run these otherwise I can shop around and take the 5s back.
Thanks in advance for your input.
Roy
Online Tom H
Re: Loop Plugs
« Reply #1 on: April 16, 2021, 12:28:14 AM »
I would go with the 6 unless you have a reason to go with 5. Too hot could cause problems.
Check fleabay, sometimes you can find a good deal on the 6.
Offline moto-uno
Re: Loop Plugs
« Reply #2 on: April 16, 2021, 12:35:42 AM »
You might even find them in a m/c shop . Too hot could lead to preignition  when hot  and under
heavy throttle. Peter
Offline guzziart
Re: Loop Plugs
« Reply #3 on: April 16, 2021, 07:11:19 AM »
Roy
FWIW, I have never had a problem getting NGK's at the local auto parts stores (Autozone, Advance & NAPA).
Re: Loop Plugs
« Reply #4 on: April 16, 2021, 08:20:46 AM »
I don't use NGK, you might try Champion N5C if you can't find the other. Autolite also makes a good plug for them.
Re: Loop Plugs
« Reply #5 on: April 16, 2021, 08:25:02 AM »
The BP6ES (and all other non-resistor NGK plugs) have been discontinued, what's still available will be old stock. The only place that I'd been able to find them was ordering from Kawasaki through my local mega-dealer, but that supply has even dried up.
No biggie - I'll just use the BPR6ES and non-resistor caps to achieve the same thing as before.
I never use Champion on anything with an aluminum head and Autolite seem to foul easier.
Offline n3303j
  • Ron Cichowski
Re: Loop Plugs
« Reply #6 on: April 16, 2021, 08:33:01 AM »
NGK also seems to show up under their somewhat meaningless stock numbers in auto part stores.
Part BP6ES = STK 7333 (Per NGK)
But on my last hunt for the non-resistor versions for my T3 I came up empty handed.
Plenty of BPR6ES around though.
They seem to work in my application.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Re: Loop Plugs
« Reply #7 on: April 16, 2021, 09:31:51 AM »
Thankyou gentlemen, I printed out this thread to take with me in my quest for a suitable plug.
The old Eldorado is going great since I put it back together, 60 PSI oil pressure and no rattles
I did a compression check, 170 PSI on both sides.
I had forgotten what aa sweet ride this old girl affords, in city traffic it's way better than any of the modern bikes I have.
« Last Edit: April 16, 2021, 09:42:46 AM by Kiwi_Roy »
Offline moto-uno
Re: Loop Plugs
« Reply #8 on: April 16, 2021, 11:19:46 AM »
  You're making me want to get my (much modified ) Le Mans 2 back on the road .  Peter
Re: Loop Plugs
« Reply #9 on: April 16, 2021, 08:23:14 PM »
Next time you come to coffee bring that or the Peterbuilt, the guys havent seen either.
Offline TOMB
Re: Loop Plugs
« Reply #10 on: April 16, 2021, 10:18:20 PM »
1970 timeframe
In the loop owners/riders manual when new the plugs were
Ambo Bosch W225T2 - Champion N4  = NGK B7ES
Eldo Champion N3  = NGK B8ES
no extended tip plugs Except N7Y Champion were optional
But the extended tip plugs may have been a new recommended as the newer models came out , BUT that was also when Unleaded gas
was  starting to appear 1970  and extended tip plugs maybe helped with the pinging
TOMB
« Last Edit: April 16, 2021, 10:32:20 PM by TOMB »
TOMB
CENTRAL CONNECTICUT
1972 AMBASSADOR 169000 MILES
1978 G5 170000 MILES
1973 V7 SPORT 25000 MILES
1973 ELDORADO 300000+ MILES
1980 CX100 50 MILES
MGNOC # 2723
Offline guzziart
Re: Loop Plugs
« Reply #11 on: April 17, 2021, 08:37:42 AM »
Good to know, thanks Charlie!  I'll have to check my stash, see what is still available locally and go from there.
Offline Moparnut72
Re: Loop Plugs
« Reply #12 on: April 17, 2021, 08:20:04 PM »
BP6ES are readily available anywhere. It is a common plug.  I used them in my race outboard.
kk
Mopar or Nocar
Current Bike:
2026 Triumph T120
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Re: Loop Plugs
« Reply #13 on: April 17, 2021, 08:35:45 PM »
kk
Up until mid 2020 they were, that is no longer the case. All of my usual sources are out of stock, ebay and Amazon sellers send BPR6ES. The only place source I'd found (through Kawasaki) has now also dried up.
Offline Moparnut72
Re: Loop Plugs
« Reply #14 on: April 17, 2021, 10:24:25 PM »
I found over a dozen on line in under a minute. Yes they are getting scarce but they are out there.
kk
Mopar or Nocar
Current Bike:
2026 Triumph T120
1976 T3 disaster
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Re: Loop Plugs
« Reply #15 on: April 17, 2021, 11:42:21 PM »
I went to NAPPA today, they had the BPR6ES in stock so I got those.
Re: Loop Plugs
« Reply #16 on: April 18, 2021, 07:39:07 AM »
kk
As I wrote above, my experience is that you can "find" them online and order them, but what actually shows up isn't a BP6ES, but usually a BPR6ES. Been there, done that four times. I ordered 8 from NAPA which was the maximum quantity they still had available. I'll see Tuesday if the correct plug shows up.
« Last Edit: April 18, 2021, 07:47:06 AM by Antietam Classic Cycle »
Re: Loop Plugs
« Reply #17 on: April 18, 2021, 08:47:34 AM »
The Lady at NAPPA didn't even point out that their's had the "R", I will see if I can eliminate that from the cap so I don't have 2 "Rs" in series.
At least I have the right heat range "I think"
« Last Edit: April 18, 2021, 02:41:43 PM by Kiwi_Roy »
Online Tom H
Re: Loop Plugs
« Reply #18 on: April 18, 2021, 10:58:19 AM »
NGK plug caps can be had at 1kohm. Have never found the 0ohm. I think it was LB01 then if you want stud or cap connection.
Offline ampm7
Re: Loop Plugs
« Reply #19 on: April 18, 2021, 01:11:43 PM »
I second Charlie's BPR6ES recommendation as I use them in my two Ambos and they work fine.
1970 Moto Guzzi Ambassador, 1998 EV, Honda 1972 850 Ambassador, 2022 Indian Super Chief Limited
Offline pete mcgee
Re: Loop Plugs
« Reply #20 on: April 18, 2021, 03:30:14 PM »
Buy platinum plugs of the same heat range and change to the zero ohm plug caps.
Saves a lot of wear and tear on the plug hole threads.
I have had a spark plug thread fail and spit the plug out, had it helicoiled and went platinum to reduce the frequency ofspark plug replacement.
Worth considering.
Re: Loop Plugs
« Reply #21 on: April 18, 2021, 03:47:40 PM »
They were what NGK recommended up until recently, then it changed to BPR6ES.
