Author Topic: valve procedure help  (Read 1177 times)
Offline lad
« on: April 17, 2021, 03:12:17 PM »
doing the valves on a 96 cali 1100i and i came across a procedure that mentions re-torquing the heads, from step 8 here:
https://www.webbikeworld.com/moto-guzzi-valve-adjustment/
is this a thing? or is the v twin a different beast to mine? never heard of it, nor finishing off the last bit of torque the next day
'96 1100i
Offline Vagrant
Re: valve procedure help
« Reply #1 on: April 17, 2021, 03:22:04 PM »
that was a first service thing only for older bikes. just ignore it.
Offline lad
« Reply #2 on: April 17, 2021, 05:47:33 PM »
cheers. i ignored it. thank you stranger.
i know there’s a lot of controversy over what to set valves to. i’m going back to stock 10/15 i/o as i’ve backfiring going on. they were a bit out, Left was 15/22 and Right was 20/23. i know some people set it to 15/20 so maybe they moved from there.
a quick polish of the heads, balance the bodies, and i’ll test it on the road
'96 1100i
Offline acguzzi
« Reply #3 on: April 17, 2021, 05:54:45 PM »
if you fit new head gaskets it's a thing, they compress and re-torqueing is necessary. In fact its best to check after it has been run a few times.
