Author Topic: Headlight dimension of California Special / V11 Bassa  (Read 1290 times)
Offline nikos900
« on: April 19, 2021, 08:34:49 AM »
Hello all,
I bought a used headlight for a 1998 California Special but unfortunately it seems a little smaller in diameter. I measure it at approx 18cm where the one that was fitted (not original) is a bit over 20cm. Do you know if 18cm is indeed the original headlight diameter and therefore I will need some spacers? (which I don't see in the parts diagram..)
Online bad Chad
Re: Headlight dimension of California Special / V11 Bassa
« Reply #1 on: April 19, 2021, 02:40:14 PM »
Yes, the Bassa and Special have a significantly larger headlight bucket than early Ev’s.
Offline nikos900
« Reply #2 on: April 20, 2021, 07:26:12 AM »
Thank you, that makes sense then.  :thumb:
