Author Topic: Kickstand Extension Pad  (Read 3413 times)
Online Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
« on: April 19, 2021, 12:37:06 PM »
Since adding so lightly longer fork springs and rear shocks to my V7, I wanted to knock out the extra lean that my V7II now has when the side stand is down. Found nothing model specific, so I gave this $40+ aluminum piece on Amazon a shot.
Fits the stand foot almost perfectly, just a hair loose depth-wise. I’ll see what a cut-out piece of super thin cutting mat does for shimming. A tad heavier than I expected. Should provide enough of a riser to ease my tip-over concern and provides a wider foot for those sandy / dirt areas. Definitely adding some blue loctite.
Motorcycle Side Stand Enlarger Plate Kickstand Extension Pad Support Plate For Moto Guzzi 1200 Stelvio 8V NTX 1200 Stelvio 8V STD/NTX 1200 Stelvio NTX ABS 750 V7 Special-Stone 1200 Stelvio (Black) https://www.amazon.com/dp/B08733M8C4/ref=cm_sw_r_cp_api_glt_i_VE9Y92HXAD1DETE0VBHX?_encoding=UTF8&psc=1
Online Perazzimx14
Re: Kickstand Extension Pad
« Reply #1 on: April 19, 2021, 01:01:31 PM »
Hockey puck and a couple #8 screws also work a treat at widening the footprint and lessening the lean angle.
Online Dirk_S
« Reply #2 on: April 19, 2021, 01:06:13 PM »
Yeah, I should’ve thought of that before buying something, but for some dumb reason I was hesitant of the idea of drilling into the stand’s footpad... even though I considered having something welded on.
Offline egschade
« Reply #3 on: April 19, 2021, 07:40:10 PM »
$12 China cheapie from eBay. Had to use slightly longer screws which got blue thread lock treatment. https://www.ebay.com/itm/Universal-Motorcycle-CNC-Kickstand-Sidestand-Extension-Pad-Plate-Foot-Side-Stand/174536871700
« Last Edit: April 19, 2021, 07:41:25 PM by egschade »
The elder Eric in NJ
Past Guzzis:
2016 V7 Stornello #394
2018 V7 III Carbon Dark
1985 LeMans 1000
2020 V85TT Adventure
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
Offline John Warner
  • Growing old is mandatory, growing up is not . . .
    • Stelvio/V85 Owners Group FB
« Reply #4 on: April 20, 2021, 01:34:14 PM »
. . . even though I considered having something welded on.
That's what I did on my Stelvio.
Doc out . . .
Stelvio Owners Group on FB ~ https://www.facebook.com/groups/888995181188209/?fref=nf
