Author Topic: New parts from Harper's. Fix those saggy signals  (Read 2080 times)
Offline Curtis Harper
    • Harpers Moto Guzzi
« on: May 05, 2021, 02:21:30 PM »
Hey guys, something I've been working on for a while and was ready to upload but with the website crashed, I have been focusing on that. For years we have all known the turn signal set up on the Cali's and others are horrible and as soon as you fix the signals, the taillight breaks. One of the reasons as we know is big junky turn signals on crappy mounting set ups. I built a plate like this years ago for my own Cal 3 and it worked  pretty well, but never made it to the front burner for production. I decided to go ahead and get this project going again.
So we have taken possession of the first run of these turn signal bracket kits. I have them for the front and the rear. I will be offering them with or without turn signals. The rear bracket is a steel piece the wraps around the taillight housing and screws in at four points and is quite stable to hold many types of signal that uses a 10mm mounting stud. The front is a tear drop shape that has a locating spacer to locate and stabilize it in place. Also 10mm hole for turn signal mounting. The rear bracket will be $24.50 each and the front $24.50 for the pair. Signals in pics are $34.95 for a pair. While the site is down , if interested call me 816.697.3411
They are first attempt and still have a few bugs to work out for the rear. At this point the metal they are made of is a bit stiffer than I wanted and they have to be bent a bit to get them around the taillight body to mount. But the second run will be fixed, and probably a few more dollars.  Probably should get all the bugs worked out before telling anyone but I didn't want everyone thinking we were out of business and not doing anything while the website gets fixed. Let me know what you guys think.
www.harpermoto.com
1-816-697-3411
curtis@harpermotocom
Offline AJ Huff
Re: New parts from Harper's. Fix those saggy signals
« Reply #1 on: May 05, 2021, 03:27:16 PM »
Nice!!!
-AJ
'71 Ambassador
'01 California Special
'05 Road King
MGNOC# L-753
« Reply #2 on: May 05, 2021, 06:57:07 PM »
I'll need a kit for the rear signals on my Jackal.
Offline 80CX100
« Reply #3 on: May 05, 2021, 10:16:02 PM »
Very nice looking!  :thumb:
Will that unit also replace the pos failure prone stock CalVin tail light support bracket? or is it only suitable for earlier Calis?
2008 California Vintage
2003 V11 Lemans
1979 G5 & 1980 Lemans CX100
« Reply #4 on: May 05, 2021, 10:25:18 PM »
Offline s1120
« Reply #5 on: May 06, 2021, 07:33:20 AM »
Looks nice!!  I dont need them (yet) but Ill keep a eye out for the next run, and maybe pick a set up for when I do.. Because we all know its not IF they break, but when...
Paul B
« Reply #6 on: May 06, 2021, 08:20:25 AM »
 :popcorn:  Oh  Currrrrrtis??????
Offline Ncdan
« Reply #7 on: May 06, 2021, 08:33:00 AM »
Are these replace lights or stems for the crappy rubber ones like all four turn sideways have fell off my 02 Stone?
Offline red2002
« Reply #8 on: May 06, 2021, 08:50:41 AM »
Curtis,
Interested in the aluminum turn signals.
Looking at your website, items 51 196 and 51 197 are listed and I can't tell from the picture if they're the ones you're showing in your post.
Need a pair of them, but want to make sure I order the right ones.
Can you help?
Thanks!
« Reply #9 on: May 06, 2021, 09:48:40 AM »
Curtis,
Can you help?
I have those on my LeMansIII they're pretty nice!
Thanks!
« Reply #10 on: May 06, 2021, 12:08:54 PM »
Red, yes they are the same signals.
NcDan, yes for your 02 Stone, that is actually what they are on in the pictures
80CX100, Sorry not for CalVin
www.harpermoto.com
1-816-697-3411
« Reply #11 on: May 06, 2021, 02:15:45 PM »
Are you putting together a kit so it all comes together?
« Reply #12 on: May 06, 2021, 02:48:47 PM »
Yes. You can buy it any combination you want but I will have kits made up
www.harpermoto.com
1-816-697-3411
Offline Ncdan
« Reply #13 on: May 06, 2021, 08:58:36 PM »
Thanks Curt, the next one breaks I’ll get all four!
