V9 Roamer Rear Pegs
Topic: V9 Roamer Rear Pegs (Read 1028 times)
tris
V9 Roamer Rear Pegs
May 06, 2021, 03:16:51 PM »
I run a solo seat on my V9 Roamer and keep looking at the rear pegs that wont be used
Is there any reason (possibly structural?) why I couldn't take them off
I can't think of/see one but I thought I'd check with the mighty WG wisdom pool first
Cheers
Tris
1995 Cali 1100 - carby "Dino" -now sold
1993 TW125 "POS" - Resting
Kev m
Not your normal Hombre
Yo from Medford, NJ
Re: V9 Roamer Rear Pegs
Reply #1 on:
May 06, 2021, 03:24:47 PM »
The Bobber Sport doesn't use those brackets so my initial guess would be they are not structural other than for the passenger's feet.
Am I right that only the top end of the brackets area bolted to the frame? Any the bottom end just hangs free?
If so you're good.
tris
Reply #2 on:
May 06, 2021, 03:36:12 PM »
Correct Kev
There are 2 bosses welded to the frame each side that the legs of the rear pegs bolt too and then hang free
I'm 99% sure I'm over thinking it but wanted a second opinion
Cheers
bad Chad
Reply #3 on:
May 06, 2021, 05:59:20 PM »
Go ahead and take them off, they are not structural. I took mine off to install the Givi rack. I put them back on as on occasion I put somebody on back, just two hex head bolts and they pop right off.
And Roamers are cool with a capital C!
Last Edit: May 06, 2021, 06:04:48 PM by bad Chad
Zenermaniac
Gosling
Reply #4 on:
May 06, 2021, 08:35:47 PM »
I saw somewhere where someone took the rear pegs and mounted them on the front frame where the two bolts are and made highway pegs.
V9 Roamer Rear Pegs
