Author Topic: 61 A10 neearly finished.  (Read 1714 times)
Rough Edge racing
« on: May 11, 2021, 04:31:18 PM »
 From a pile of mismatched parts, $4000 and a lot of labor...Most everything needed fabrication to fit...What we got is a 61 BSA Super Road Rocket uncut frame and lightly modified engine. 2000 Honda 600 CBR fork assembly and a bunch of old Brit parts...The engine is internally sock taking advantage of modern precision machine work. Mikuni 32mm flatslide carb, rewound and remagnetised Lucas magneto, I converted the generator to 12 volts and a bunch of other stuff....
Offline chuck peterson
Re: 61 A10 neearly finished.
« Reply #1 on: May 11, 2021, 04:33:44 PM »
Some guys have all the fun..
 :bike-037:
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
Offline Groover
    • Scooteropolis
« Reply #2 on: May 11, 2021, 04:34:21 PM »
That looks really cool  :bow:
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
« Reply #3 on: May 11, 2021, 04:58:40 PM »
Rough Edge racing
« Reply #4 on: May 11, 2021, 05:08:42 PM »
About 45 hp, about 380 pounds, the drum front brake for backroad thrills...Had more than a few stripped treads, the cylinder was a bugger...Bought the expensive TimeSert kits, much better than Helicoils..
« Last Edit: May 11, 2021, 05:13:46 PM by Rough Edge racing »
Offline moto-uno
« Reply #5 on: May 11, 2021, 05:43:22 PM »
  Jesus , you got away cheap  :evil: . That's gonna be so much fun , hope the fillings in your teeth are secure !
I'm almost jealous ,  Peter
Offline tazio
« Reply #6 on: May 11, 2021, 06:29:42 PM »
One of motorcyclings most beautiful engines!!
1967 Kawasaki 650 W2TT
1966 Triumph Bonneville
Rough Edge racing
« Reply #7 on: May 11, 2021, 08:19:15 PM »
When properly assembled and balanced the vibration doesn't define a few hour ride...This bike ain't exactly an interstate arm chair... :grin:
Offline cliffrod
« Reply #8 on: May 11, 2021, 08:30:14 PM »
Very cool.
Offline larrys
« Reply #9 on: May 12, 2021, 09:15:42 AM »
Lookin good. Should be a fun back road bomber...
Larry
'13 Monster 1100 EVO
'95 Cal 1100
'68 Bonneville
MGNOC 7248
Offline 80CX100
« Reply #10 on: May 12, 2021, 09:43:23 AM »
Rough that's amazing,  :thumb:  :bow:
It'll be nice and light on a curvy back road.
Tks for sharing all those photos,, all those classy curves and shapes on the outside of the engine, make sense now that I've seen what the innards look like  :laugh:
Wishing you many safe miles on your new ride
2008 California Vintage
2003 V11 Lemans
1979 G5 & 1980 Lemans CX100
Rough Edge racing
« Reply #11 on: May 12, 2021, 10:29:45 AM »
The A10 has a fully welded frame that was quite rigid for the time period. I did some  spring  work on the CBR forks that have fully adjustable dampening.In the rear are older Koni shocks with adjustable dampening...
Offline borderer
« Reply #12 on: May 12, 2021, 02:00:38 PM »
I have a Super Rocket 1961 n RGS spec (in the UK it was either a road rocket or a Super Rocket) Spitfire cams, RGS valves, Balanced crank SRM Roller main bearing conversion, eddie Dow front fork conversion and Triumph twin leader front Brake. Have owned it for 38 years !! bought two for £175 one in bits and this one, sold the bits for around £200. It used to be my main (only) transport lost track of the miles done but it must be well over 100000 miles. not so many miles now since guzzis came along. There is very little vibration at normal riding speeds, its easy to alter the gearing to move vibration out of the way. alltogether its been a good reliable bike with only one big engine failure when an oil line split at motorway speeds. Hence he roller conversion etc etc. I used to run high comp pistons but that needed 5 star petrol so don to 9.5 to 1 now. It can still give more modern bikes a fright on the right road.
